Question about Scosche Rsa1400A 1-Way Am Alarm & Remote Start
Alarm remote is not communicating with car
I have a scosche rsa1400 remote start alarm. The remote is not communicating with the alarm properly. The doors work the alarm sets the remote start works . However you can not tell on the remote if the car is in range and if it started or if it's locked or not?
  • 365 Answers
These units are troublesome...you'll have to take it to a car stereo shop that does alarm installations and have it diagnosed or replaced...Don't buy another Scosche.
Good Luck
Posted on Jun 22, 2009
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
I recharge my battery and try to put it back conet and the horn keep blowing when try to start get nothing in side or out
It sounds like the car alarm is going off. Do you have an alarm remote that you can use to turn off the alarm? If the alarm is sounding, the anti-theft system will NOT let you start the car.
Dec 23, 2011 | 2004 Acura 3.5RL
I have misplaced my remote control key after returning from work. How can I find it please?
If you know its at home or near there. Lock/arm the security system from the 1way remote and then set the alarm off either by opening door with the KEY or hitting the car to set off the shock sensor. The 2way remote will start making lots of noise AS THE ALARM IS GOING OFF.
Now if you lost the 1way remote, there is really no easy solution except your eyes.
cheers!!
Sep 04, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
My alarm keeps going off on my 2007 Sonata. Ive located the fuse box but cannot figure out which one disables the alarm or horn until I can have it looked at. As of now I disconnected the battery.
TAKE THE KEY THAT UNLOCKS YOUR CAR DOORS PUT IT IN THE LOCK TURN IT BACK TO THE LEFT AND HOLD IT FOR ABOUT 10 SECONDS THIS METHOD USALLY DISARMS THE ALARM.
Jan 02, 2011 | Hyundai Sonata Cars & Trucks
My alarm wont turn off. my car wont start. its a 2004 tiburon.
With alarm activated your ignition is disabled.Find the combination to disable it.With GM's you hold opposing buttons on the fob till it beeps twice. The dealer should help for no charge.
Feb 28, 2010 | 2004 Hyundai Tiburon
Don't have remotes anymore. Alarm keeps going
chop it out / the alarm system is wired paralel / here's a site that will help ( www.the12volt.com ) good luck
Nov 19, 2009 | 2003 Toyota Corolla
I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Jan 28, 2009 | 5900 SST 2-Way Security System / Remote...
Scosche Rsa1400A 1-Way Am Alarm & Remote Start Logo
391 people viewed this question
Top Scosche Industries Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Scosche Industries Vehicle Part and Accessory Expert? Answer questions, earn points and help others
