Question about Vtech 9009111 Cordless Phone
Phone numbers not showing on caller id LED screen.
Can you please tell me how I can get the numbers to display legibly again on my Vtech 5.8 digital phones? They showed very clearly before, but after three years, they are very faded. Thanks.
  • 44 Answers
Disassemble the handset (if you can figure out how to get it open). Flip the LCD screen over so that you can get to the end of the wire ribbon. You want the end that is connected to the phone, not the LCD screen. Carefully use a heat gun or hair dryer to heat the cable being careful not to melt it. Your goal is to melt the glue that connects the tiny wires to the electrodes. When glue is melted use a pencil eraser to press the wires so that they make contact again. Let it cool and try it out. It should work well after that. Put your phone back together.
Posted on Jun 28, 2009
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
Want to know if cs6319-4 VTech cordless phone has bluetooth capabilities?
No........
CS6319-4 Features:
  • New DECT 6.0 Technology
    - Interference Free Communication
    - Increased Clarity / Enhanced Security
    - Wider Range / Network Friendly
  • 1.9GHz Cordless Phone
    - Dedicated for Cordless Phones by the FCC
    - 30% Battery Life Increase Over 5.8GHz
  • Caller ID / Call Waiting
  • Expandable Up To 5 Handsets
  • Wall Mountable
  • Handset Speakerphone
  • Backlit LCD Display
  • Backlit Keypad
  • Name / Number Caller ID Memory
  • 100 Station Phone Directory / Dialer
  • Conferencing
  • Selectable Ringtones
  • Handset Volume Control
  • Handset to Handset Intercom
  • Call Transfer
  • Last Number Redial
Jun 03, 2011 | Vtech Lands Phones
Hi... I got the Vtech Cordless phone Dect 6.0 the caller id is not working. it just shows "Incoming call". I tried with Panasonic cordless to check if I have no problem with the service...
hi you need to programme the number into you caller id unit or extension.Also you need to confirm that caller i/d is envoked by your service provider. and ask them to test it .
Best regards
John
Mar 14, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How do you delete missed call message from vtech 6.0 phone
Open the caller ID screen and scroll through the recent calls. Hope this helps =]
Mar 01, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
ID quit registering
I just unpluged the system and pluged it back in. Didn't loose any information and it started working again.
Dec 07, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Mar 06, 2008 | Vtech ia5864 Cordless Phone
Vtech 9009111 Cordless Phone Logo
1,336 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
