Question about Hoover F5906-900 Upright Steam Vacuum
How do you get the Hoover steam Cleaner to **** the water back out of the carpet?
It's not picking up water that is on the carpet
Posted on Jul 19, 2009
reddevil6
  • 1673 Answers
SOURCE: Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Posted on Jan 10, 2008
SOURCE: hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
Posted on Mar 09, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
  • 294 Answers
SOURCE: Where can I find a user manual for a Hoover Steam
The manual can be downloaded at Hoover.com for your exact model
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Oct 11, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Why does water pour out the back when I use carpet steam cleaner
Hey there! It sounds like your cleaner is leaking. That can mean an issue with your pump assembly. We recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jul 01, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Operationing instructions for hoover model fh50020rm carpet clearner
I have an Hoover Steam Vac Carpet Cleaner Model# FH50020RM, it's not working. The water is not coming out and not retracking the water.
Jun 05, 2011 | Hoover Vacuums
I have a Hoover steam vacuum carpet cleaner Model
the lever on the handle should be pressed when you want to apply solution to the carpet
Dec 29, 2009 | Vacuums
There is no steam on my hoover steam vac
They do not really "steam." They use hot water to clean your carpets with a mix of cleaner as well. You will not see your unit actually steam.
Dec 09, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5906-900 Upright Steam Vacuum Logo
157 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
