Question about Whirlpool 24 in. DP940PWP Free-standing Dishwasher
Whirlpool 24 in. DP940PWP Not Draining on Second Cycle
Hi all,
Out dishawasher of the make above will run and drain fine up until the second (rinse?) cycle and then doesn't drain. If, at the end of the cycle, you press the cancel/drain button it will drain the standing water left from that last cycle.
Any thoughts?
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
SOURCE: Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Posted on Mar 21, 2009
  • 864 Answers
SOURCE: No water running through cycle once filled....making humming noise once clicks into cycle
Both problems sound like motor has failed or is failing.
Posted on May 29, 2009
  • 46 Answers
SOURCE: Dishwasher stopped without fully draining water
if it is pluged into gfa plug it might be triped
Posted on Jun 26, 2009
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
My Whirlpool GSQ9364HQO washer will not drain, pump is ok.
Lid switch OR timer connection block loose, or motor capacitor OR sock in hose to pump. Service manual and more is HERE
Jun 12, 2012 | Whirlpool Washing Machines
My dishwasher is draining properly.
yes there is cleaners.Check filters at bottom of machine fiirst,then buy an cleaner.adrian,,,,
Jul 15, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
The dishwasher does not completely drain.
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jun 10, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
Not draining after rinse cycle
replace the timer it has a bad spot inside of it in this segment of the timer and isn't passing voltage for spin,when you forward it then it gets power again,they do wear out too
May 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Duet washer has a strong odor when draining
you might be getting "sewer gases" from your drain, but most likely your washer is the cause of the odors.
does it also smell musty when you get your clothes out?
whirlpool makes a product called "affresh" that is specially designed to clean out the residues from a front load washer.
you can find them at sears or lowes and the come in a package of 3 tablets. run a tablet on the clean cycle or on whitest whites or the longest cycle you can choose, use hot water and a second rinse option.
also to prevent this odor in the future make sure you are using only HE type soap and dont use too much. the least amount should do well to clean any clothes.
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Whirlpool 24 in. DP940PWP Free-standing Dishwasher Logo
41 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
