Question about George Foreman G5 Indoor Grill
No lights on the display when I plug it in the outlet.
Also it will not turn on or heat up. I have the GRP99 model.
    President:
  • 1,185 Answers
Check the fuse in the plug top
If that is OK then look at the wiring at the plug end the grill ends
Wiggle them about with the power on to see if there is a broken wire
If not you are down to either getting soemone to strip it down or buying a new one
Posted on Jun 21, 2009
Frigidaire microwave not heating over the range
Hello
Try to cook something simple such as microwave popcorn. If the unit does not light up or turn on, check the outlet with another appliance to make sure the outlet is functioning correctly.
Check the fuses or circuit breakers in you house. If the outlet does not work after testing it with another appliance, try to plug the microwave in a different outlet.
Check the hinges and door hooks to make sure the door is closing properly. Look to see whether a small piece of food is clinging to the door, preventing it from closing all the way. Check the release mechanism and the rotating plate to make sure they can move freely as well.
Plug in the microwave and start it a the bag of microwave popcorn inside. If the lights go on but it is not producing heat, listen and try to hear whether the unit sounds the way it usually does. If it does not, there might be problems with the circuit board. This will need to be repaired by a certified Frigidaire professional.
Check the display that shows the time and power. If the display is flickering but it does not alter the operation of the microwave, it is not a problem. If, however, the lights flicker and your food is not heating, there may be a problem in the microwave cabinet.
Listen for buzzing sounds. If there is a buzzing sound and no heat is being produced, you may have to get a new magnetron, power diode, or high-voltage capacitor. These can be purchased from a Frigidaire retailer.
Look at the handle on the door. The most common complaint about all models of the Frigidaire microwave, according to Consumeraffairs.com, was cracked or broken door handles. Frigidaire will replace faulty handles while the oven is under warranty. In many cases, they will replace the handle even after the warranty expires for a "reasonable" amount of time.
Oct 04, 2011 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
I have a George Foreman Grill Model GRP99 Series. When I plug it in the panel does not light up. It appears to be heating. I can not tell how hot it gets because the panel is not lite.
the indicator light doesn't have anything to do with how hot the grille gets,that is preset by an internal thermostat and the light just comes on when that temperature is reached, more than likely the miniature neon bulb that light is burnt out, any appliance repair shop can replace this bulb for you
Jul 30, 2010 | George Foreman GRP99 Indoor Grill
Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
Request manual Model#GRP99
GRP99 - George Foreman OWNER'S MANUAL Grilling Machine GRP99 click this manual
Jul 08, 2009 | George Foreman GRP99 Indoor Grill
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
GRP99
Everything you described is normal, except not heating up.
When you first plug it in, you will see 'dashes' that tell you it is getting power.
When you press the Power Button, the grill will start at the Default Temp of 300F and the Timer starts at 5 minutes. You now change the temp to what you want.
It takes 5 minutes to get your grill to your tempreature, so the timer should 'count-down' as the grill heats up.
As for not heating up, I think you will need to get that 'looked at' for repairs.
Mar 18, 2008 | George Foreman GRP99 Indoor Grill
George Foreman G5 Indoor Grill Logo
334 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
