Question about Dryers
Dryer problem My dryer it made so mush noise during drying.At first I thought it was a belt but I checked still good condition.I just have no idea where it came from. please help. Thanks
  • 909 Answers
Possibly some "fluff" in the blowing fan. Or bearings in a metal on metal sound.
Posted on Jun 21, 2009
Drive belt tension problem- squeeling belt during drying.
Hi mhairi_colga
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers are in need of lubrication
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Apr 19, 2013 | Dryers
The electric dryer will heat up to dry the clothes but it has a high pitch noise when you start it and periodically during the drying time it will make that sound. At first I thought it was the belt but...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 25, 2011 | Maytag Dryers
We have a Kenmore Elite electric dryer H4. For the last week it has been vibrating and making a loud noise, but still drying the clothes. Now the noise is unbearable. We can't use it. Any idea? Is it...
I believe it is your drum rollers in need of lubrication or replacement...
-----------------------------------------------------------------------ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me------------------------------------------------------------------
Jan 13, 2011 | Kenmore Dryers
Why is my dryer is making a lot of noise during drying process?
check to see if it is a belt pulley system if it is its probably those items.
Apr 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
LG Dryer is banging loudly during its cycle. Sounds like when shoes are being dried inside it with all the clunking
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Mar 02, 2010 | LG DLG2525S Electric Dryer
Dryer making knocking sound
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Nov 13, 2009 | Kenmore 62602 Electric Dryer
My maytag neptune dryer thats electric when it is drying makes very load squeaking noises. Its sounds very bad, but it is still drying the clothes? what might be the issue?
Check your rollers for flat spots, if they have flat spots on them replace them.
If the rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Nov 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud noisy squeak
Now is a good time to check the belt to see the belt condition for wear.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Nov 03, 2009 | Hotpoint Dryers
Lg dryer
My LG dryer makes too much noise during dry cycles. What part do I need to replace? Do you have an online manuel? My email is drlofton@aol.com
Jul 30, 2008 | LG DLE2532W Electric Dryer
Real bad squeaking noise in dryer
There should be a access panel in the back of the dryer to get at the belt and pully. You can check the belt operation from there. If that all seems good you will need to remove the front of the dryer and check the drum supports in the front and the rear support rollors.If you hear the noise more from the front I would say the front supports are the ones thst should be replaced. And yes you can purchase a repair manual for that dryer at a parts store. Good Luck
Jul 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
