Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Buzzing Noise coming from GE Stovetop.
Behind the clock and light on our GE stove, there is a buzzing noise that is constantly making noise. I don't know what it is, but it's driving my wife and I nuts.
It's a constant noise.
  • kevingodby Jun 21, 2009
    Might be it,
    If I smack the clock area, sometimes the noise will stop for a few seconds or change pitch. I will try.
    Thanks,
  • 439 Answers
It could be a loose transformer that needs to be remounted. Pull the stove out, remove all of the screws at the top and visually inspect the transformers and wiring. This should be an easy fix, but if you leave it too long then your stove will malfunction. I hope this helps at least get you to the next step.
Posted on Jun 21, 2009
  • Paul Cooper Oct 15, 2012
    How exactly do you get access to the wiring?
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Constant buzzing noise, must be transformer but stove works perfect. is this normal
Look to see if coiled gas line is vibrating against back of stove. (Or try pulling stove forward a bit).
Otherwise, you are probably correct about a transformer. It can be ''defective'' and still work.
May 18, 2015 | GE Profile JGP636 Gas Cooktop
Royal chiantishire buzzing how to fix
I have the same buzzing ticking clock sound much too noisy. Can't find a way to get to the clock
Mar 19, 2014 | SNK Fratelli Onofri Royal Chiantishire...
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
Frost build up in freezer, makes a buzzing noise.
The problem was fixed by replacing the "bi-metal" device. The fan was making a buzzing noise because it was hitting a build up of ice on the coils and behind the whole back panel.
The bi-metal device was bad and "bulging" out and not performing like a switch. It kept the compressor going all the time and never allowed the freezer to go into the "defrost" mode.
Oct 15, 2009 | Roper Refrigerators
Built-in microwave bottom light problem
it may be the noise is not seated properly check that the light is connected properly? check all the screws. are tight? and the machine is level?
Mar 17, 2009 | Maytag MMV4205 Microwave Oven
Buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
May 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Buzzing noise, wont work???
The magnatron is shorting, overloading the high voltage transformer. From the picture this looks like an older unit and is probably not worth a magnatron replacement.
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
2,561 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
