Dvd drive tray will close but spring right back open
    Novelist:
  • 152 Answers
More than likely, there is something wrong with the internal latching mechanism, either it has been broken, or is " clogged " with debris. Also make sure there is nothing else inside of the drive that may be interfering with the drive tray, or tray track.
Posted on Jun 21, 2009
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
Tip
How can you access the rubber belt when the tray is closed? I Can't ! I had the...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on May 02, 2009 | Samsung DVD-V4600 DVD Player/VCR
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
JVC Model DR-MV99 tray door keeps opening and closing when trying to insert a DVD disk
This problem was driving me crazy, until I found a solution.
This is what you need to do.
When the tray is open grab the flap door that goes up when the dvd goes in. Hold it down as you the DVD tray goes in. (Its spring loaded) This allows you to have direct access to the front of the tray even when the DVD goes all the way in. Hold the tray in with your finger by pushing in firmly on the far right corner of the DVD tray. The DVD tray will try and come out, continue to hold it in while pressing the eject button on the remote. If you are firmly pressing in on the right corner of the tray it should only take a few times of pressing eject when you see the Disk symbol on the screen and you will here the DVD start loading. When you know that it is starting to load release the front door flap. You can then use the DVD player as normal.
Unfortuntely you will need to do this each time a DVD is loaded.
Jan 24, 2011 | JVC Televison & Video
Unlock toshiba SD800ky
2. Press the Open/close button on your remote control to open the drive tray; remove any disk and leave the tray open.
3. Press 2,4,0,3,9,6,0
4. Press 9 for multi-region playback. You will see a "9" appear in the upper right hand corner of the TV. DO NOT Press Enter button on your remote control
5. Press the Open/close button on your remote control to close the drive tray, and power off the DVD player before it says "no disc".
6. Power the DVD player back on and it is region free !!! Woohoo !
Jan 09, 2010 | Televison & Video
The tray wiyll not stay closed and sometimes will not open or closed.
hi
maybe you have bad contact in micro timing switch, and this micro switch needs cleaning then test run.
Thanks!
Jun 06, 2009 | iLO DVDRH04 DVD Recorder
THE DVD TRAY KEEPS OPENING
check if the power hubs on the back of the back of the drive are hooked up right if they are un hook and hook back up while your pc is off
Mar 13, 2009 | LG GSA-H55N DVD-RAM Burner
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
X box tray
There may be something jamming the gear inside the drive causing the motor to spring the tray back out.
Hope this helps
Jan 09, 2008 | Microsoft Xbox 360 Console
Combo drive opens and closes automatically
Arav you will have to open this unit up, sounds as thought the units slider has passed the spring sensor. with the unit open manually open the tray, there should be a spring lock release on the right with it upside down facing you. slide the tray all the way back in until you hear it click and lock. You may want to do this several times to make sure no plastic pieces have broken off. If you see or find a piece come out then achances are the spring lock mechanism has snapped, not uncommon on this drive. The screws are easily located on the bottom.
Sep 12, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
