Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
Cookie reboots when i connect to my parrot car kit
When i try to connect my cookie to my parrot car kit it just keeps switching off and restarting
  • 952 Answers
Your phone is probably not compatible with the car kit... try updating the phone firmware or check with the car kit support...
Posted on Jun 21, 2009
My parrot mki9200 keeps powering down and then rebooting itself, i have put in the very latest software but that hasnt helped. does anyone know what else i can try
There is newer software version 2.0 which should help, does the same thing happen with other phones?. sometimes the phones have software issues which affect how the Parrot works.
Oct 07, 2011 | Parrot Hands-Free Car Kit with LCD Display...
When i pair my nokia e5 to my parrot ck3100 it will not stay connected it keeps disconnecting then connecting again
You will probably need the latest Parrot software for this phone to work properly. The Parrot web site lists it as fully compatable.
Sep 09, 2011 | Parrot Hands-Free Car Kit with LCD Display...
I cannot get the galaxy ace to automaticaly connect to my car hands frre kit ( Parrot )
The parrot car kit varies, there are about 10 different types of the parrot car kit and the connections varies slightly. Just follow these steps to connect ur galaxy phone to the car kit.
For this model of the parrot car kit,after the installation on your car,ensure the car is on
Parrot CK3000:
1. Start the car and ensure the car kit is on.
2. Activate Bluetooth on your phone, and search for Bluetooth devices.
3. Select "Parrot CK" from the list.
4. Enter 1234 on your phone when prompted for a password or code.
5. The Parrot CK3000 will sound a beep when connected to your phone.
Your phone has now been paired with the Car Kit and is ready for use.
For other models of the parrot car kit,repeat step 1 & 2 above and for step 3, u select the model name like "parrot EVOL" for the CK3000 Evolution model.
Aug 30, 2011 | Samsung Cell Phones
Hi I have a parrot hands free kit which was
You can purchase a special adaptor lead to allow the parrot to just plug in to the back of the radio, this is called a SOT lead, do a web search and you will find the right one. Try autoleads or kram are good manufacurers.
Jun 17, 2010 | Parrot Hands-Free Car Kit with LCD Display...
New mobile pone that won't pair with Parrot CK31OO. Tried 1234 which is default but keeps getting rejected. Any clues plse? Thanks
Just make a look to the kit to ensure that there is not already five phone s paired to the kit.
You can try also to reboote the phone, retreiving the battery of the phone during a minute and put it on again. Make the research and then try once again.
You may have a specific info passing through the kit during the pairing, then precise to ensure the diagnose.
You can also using the menu of the kit, settings -> advanced settings-> pair with phone and then activate one of the menu to help both products to recognize better each other.
Mar 31, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Wire connection
try doing a web search for part number 86117 this is a Kram teleom part number to adapt you car to a parrot.
DAN
Feb 21, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot Glicches
sometime, it my be in relation with the install.
Just a simple question, did you install it by yourself? if yes, did you connect the mute cable of the kit? cause if you disconnect it and try to make working the kit and see if the mute is working may be the explanation. signal treatment.
(except trouble of the kit), after a while plugging on a 12v dc only can be the explanation. Do you have the message "good bye" on the display when you switch off the ignition key? If not, that could also be due to the fuses inverted to the vehicle between the 12 dc and the 12 ignition. Then you just have to inverse fuses.
Feb 11, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
LG KP500 cookie
Had the same problem..If you copy the contact list (Which the parrot sees empty) to the phone memory as well as the sim card then set the phone to read only internal contacts it will upload the list for you and not double up the contacts.
Only trouble is the Cookie does have a habit of shutting down and restarting every time it hooks up to the parrot or when you end a call. The problem can be helped by uploading the latest parrot software but its not a 100% cure..
Dec 20, 2008 | Cell Phones
Parrot Car Kit "no signal" detected problem
I have had the same problem and the only solution I have found thus far is removing the fuse supplying power to the radio(assuming this is where the parrot is getting power from) for some time.
Jul 02, 2008 | Parrot CAR PAICK3300 GPS Receiver
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
238 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
