Question about Yamaha Audio Players & Recorders
Yamaha RX-v420 wont turn on
I have a Yamaha RX-v420 surround reciever that will not turn on. I checked the voltage across the small trans former on the power board (which I assume is the standby power feed) and on the side with two terminals I could only read 0.5 volts accross them. Is this within spec? if not what should I check next? I have already checked the fuses.
  • 238 more comments
  • dude998866 Jun 22, 2009
    Between chassis and the two capacitors on the power board I measured 0 volts.
  • dude998866 Jun 25, 2009
    Ok so heres what I've done so far. Apon further testing the standby transformer is outting out 5 volts and seems to be fine. I have tried bypassing the realy on the power board, but this did nothing. I have also tried running power directly to the mains on the main transformer. This onky lit up all the lights on the front display, so ther was no input, just power going to it. So what should I check next?
  • dude998866 Sep 28, 2009
    The voltage across the largest capacitor is zero. The aluminum heat sink has 10 transistors mounted to it and there is no voltage at the center pin to any of them. I'll have a look for that fuse.
    Sorry for the long delay in responses, life got in the way.......
    Thanks
    I have found a schematic for it if it helps.
    http://www.eserviceinfo.com/download.php...
    it is in two parts, must download both and un rar
    I'm currently taking out the standby transformer because I think it might have had it as the schematic says it should put out a little over 12 volts. I'm going to hook up an external 12v power supply and see if it works.
    There is no power at +b4 or -b4. I believe this is because no power is being sent to the main transformer. should i still look at 401 and 402
    no power at the mains, but the windings check out fine. If you read one of my earlier comments you'll see that I've fed power directly to the main transformer and the front display lit up (all lights were on) but the rest of the unit did nothing, no relay clicks or the like.
    No power at either BR or GY
    no voltage at either
    BR and GY? they are on the power relay board.
    no voltage at q162 where you specified but i have voltage coming out of the standby transformer
    i get .6v at both GY and BR
    I don't actually have a component at q162, and i think i've tried jumping past that relay before. and yes i realize they are ac
    ac at secondary side of main transformer now but unit still does not power on. i'm on 110v
    so do i leave the jumper wires there or take them off, and what exactly am i testing now?
    no output on either B4 and there is one pin on the secondary with no voltage
    so you want me to retest everything we already tested? and yes there is 6 volts coming out of the standby
    6v
    5.7v
    25.9v
    17.3v
    0v
    17.3v
    26v
    post not connected to anything
    .6v
    1.1
    the last 2 posts after the one thats not connected feed the display, or so it would appear
    6v
    5.7v
    25.9v
    17.3v
    0v
    17.3v
    26v
    .6v
    1.1
    6v
    5.7v
    25.9v
    17.3v
    0v
    17.3v
    26v
    .6v
    1.1
    6v
    5.7v
    25.9v
    17.3v
    0v
    17.3v
    26v
    .6v
    1.1
    b4 has 36v dc at it. the 26 v was at the pin between the unconnected one and the one with 0v. Also now upon plugging it in the LCD all lights up for a couple seconds and then goes out
    measured the posts in ac
    -B4 is -36v dc
    -B4 is -36v dc
    could you give me a point to test ie. a # like ic105 as I'm not really sure where the preamp is
    check which part of that diagram?
    ic 105 was just an example
    can't seem to locate the preamp
    No relay clicks. It essentially seems lifeless
    There is no IC 105. I was just giving an example of a part number so that you'd know what I was asking for.
    What do the amps look like on the board so I can find them?
    found ic 732, which of the 8 pins should i be checking
    ok have +12v and -12v at ic 732
    q910 side of ic 903 has 15 volts at all 3 pins on other side there is 16v .6v and5.53v
    are these still on the display board?
    D910 gives me 6.6v
    each A1695 has 0v at the right pin and -50 at the center
    each c4468 has nothing on right pin and +51v on the center.
    Reset???
    Reset???
    Thank you by the way for all your help, it is much appreciated. It's also rather impressive that you can do all this without seeing it.
    what about it not turning on?
    speaker and player ready
    where is c172
    where is c172
    where is c172
    found c172, but having trouble locating r79 or r83
    can't seem to find r 79 or 83. where are re located?
    still can't seem to find them. anywhere else i could connect it?
    found r83
    found r83
    i get static but no sound
    The output at r83?
    The output at r83?
    ahh right aux, now i have sound as well as hum
    humm is gone
    humm is gone
    cool, it works..... now i'm excited, what do we do next
    the hum disappeared sound is clear now
    why are we bypassing the processor, i thought we had to reset it? and what does it mean to "inject the hanging output"?
    r 83
    r 83
    by inject you mean make contact with one of the balance knobs pins?
    I can't see a way to make contact with the RCA plug from the player and the balance knob contacts... sorry. So how do I reset the unit?
    no, i don't have a remote for it, but i do have a logitech harmony remote that is programed for it.
    i have the logitech, yes
    none, it is blank
    as in it's not working
    logitech harmony 550
    yamaha receiver display is blank
    not even background light
    I'm good to try a couple more things before turning on for the night
    are these on the display board?
    I think I'm going to have to call it quits for the night. I can't seem to locate IC803...... I'll have a go again tomorrow... thanks again
    I think the screen is fine as when it's been unplugged for a bit and I plug it back in the screen lights up completely, as in every light on it is lit up, so it's not displaying anything and then after a few seconds it goes out, So I'm assuming that it's not working because there is no signal from the processor?????
    D803, D808 both have the correct voltage as does IC 804. Although on my board IC 804 does not have the center connected, only the 3.4V and the 4.5V outside pins.
  • dude998866 Sep 29, 2009
    D808 and D803 where good, should I check the others or should we move on to resetting it and if it still doesn't work try it from there?
    I'm afraid that i can't make out the numbers on the last schematic you posted, could you tell me what they are or zoom in a bit please
    D 904=2.7v
    D 902=05v
    D 904=2.7v
    D 902=05v
    U901 gets the correct voltage and varies when I use the remote
    which board? the display one? if so it doesn't go in chassis. it is screwed into front bezel
    I have nothing at j 1005, just holes
    To put all boards back in I will have to disconnect our jumpers on the power relay board. should i leave that board loose?
    Which part would you like pic of?
    dob of solder off of j1005 has 0v
    digital multimeter, no continuity between ground and j1005
    the side of the jumper not connected to the chip has continuity to chassis
    what point is pin 21 connected to that i can test at?
    Q911=4.9v, -18.4v, 4.5v
    Q912=4.9v, -21.6v, 4.5v
    i have made all measurements with the negative on the chassis
    -29.1v @ r911 which is connected to pin 1 vfl
    R999=-22.3v
    D909= -29.1 on one side and -22.3 on the other
    R999=-22.3v
    we tested that earlier, it had 0v
    yes it's plugged in, and yes zero volts
    remember though, it's not connected to anything as there is no j1005 on my board
    pin 29 is not connected to anything. it goes to a hole where j1005 should be
    with unit not plugged in i have continuity between pin 29 and chassis
    3 pins on xl 901 i get 1.5v, 0v, 2v
    is what shorted? I just gave you those pins via xl 901
    c902 has 4.5v on one side, 0 on the other
    i take it thats a bad thing
    do you mean ic 902????????
    nvm found ic903
    Ic903= 15.8v, 0.7v, 5.5v
    should i check the voltage at D908 and C908 then?
    c908=4.9v on one side 0.0v on the other
    d908=5.5v n one side 4.9v on the other
    so my next step is to replace those 3 capacitors then?
    is c908 a special type of capacitor? i've never seen one like it before
    Oh I'm not too worried, I've replaced capacitor before. I have a couple 16v 1000 laying around, I might have to buy the 0.047f one though....is that the same as 470uf? .... I do have a couple parts boards laying around, and I beleave a couple old video cards
    i'll see what i can dig up
    will do, is that just to cover all bases?
    i could use 4 470uf electrolytic capacitors?
    replaced c907, 904, 905
    any chance I might not need to do C908???
    any diode will work?
    so 2x1uf= 0.047F?
    so 2x1uf= 0.047F?
    so 2x1uf= 0.047F?
    so 2x1uf= 0.047F?
    replaced the diode, still getting 4.5v on c902 the sides of c908 and d 908 yjat are connected both get 4.9 v
  • dude998866 Jan 22, 2010
    Sorry for absence, life got busy.... either way.... What I meant was The positive of c908 has 4.9V but the negative has 0V. I replaced D908 with no change, and I also tried replacing C908 with 2 1uf capacitors in series still with no results.
2 Suggested Answers
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
When playing the DVD when you turn up the volume the amplifier turns off.
Amplifier and an over load issue and is shutting down to protect the circuits. Needs to be checked out by tech.
Mar 08, 2015 | Yamaha RX-V420 Receiver
I need to conenct yamaha rx v420 to Samsung tv
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V420.pdf
Mar 31, 2014 | Samsung Security Cctv Sod-14c Soc-120...
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
No power
Crystal for system micro should be in front panel display and near the lcd display .while your there check solder connections in display board
Aug 05, 2009 | Yamaha RX-V420 Receiver
How much for a digital board for my yamaha a/v rxv 420 ?.an expert check my a/v and tell me the problem is the digital board.
What concerns me is why do you need a digital board, which cost around $150 or so. I just repaired a rx-v620 that needed the volume and mode crols replaced. These controls affected mant aspects of the digital circuits opperation. Your 420 could have a similar fate. What is it doing?
Jul 17, 2009 | Yamaha RX-V420 Receiver
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Dan
May 12, 2008 | Yamaha RX-V420 Receiver
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
TURNS ON BUT NO SOUND
if the amplifier integrated circuit is busted that will not sound even the power will display the front panel.
Sep 13, 2007 | Yamaha RX-V420 Receiver
Yamaha RX-V420 Will Not Power up
Hi Daniel if your set does not have a fan that trips on when the volume gets louder surely the audio output will damage. every working component generates heat and when the heat sore up to an uncontrolable level it cause damage.have a tech look on your set to repair it.good luck.
Apr 26, 2007 | Yamaha RX-V420 Receiver
1,676 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
