Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door openly opens 5-6 in, then stops.
Craftsman 1/2 HP garage door opener. Working fine until last night, when it would not open the door past 5-6 in. After repeated attempts, opened door manually. Door opener CLOSED the unit, but (again) would not open it past 5-6 in. Outside temp was 90 degrees. This AM (cooler), tried the unit, and it worked fine for 3 attempts. On the 4th attempt, the unit again failed to clear past 5-6 in.
Took off cover and examined drive gears. All gears APPEAR ok (they engage, etc) and work fine to lower the door. All springs appear ok.
Could this be a sign that the unit (7-8 years) is about to die?
    Problem Solver:
  • 4 Answers
I had the exact same problem for the last couple days. I have a 1/2 hp craftsman garage door opener and fairly heavy garage door. The problem wasn't with the opener, but with the torsion springs, they weren't tight enough. So I followed the directions here, Link. I had to make my own adjustment rod out of an old piece of steel rod, which I had to grind down to fit in the holes of the collar. Be careful, this is a two-person job, so when I did it, I had someone stand on a step ladder next to me and they loosened the screws as I was holding the bar. In order to get the right amount of torsion, I first tightened both springs about a quarter turn, and then tried to lift the door manually. It still was pretty heavy, so I gave them both another quarter turn. That seemed to be just the right amount of torsion in the springs to lift the door the way it should. Again, be careful when tightening the springs, I wore safety glasses just in case something happened. Hope that helps. Like the other guy said before, you can also adjust the force that the opener applies to get the door open, however, keep in mind this puts more stress on the motor and chain, which could shorten the life of both components. If what I said here doesn't help, you can also get the torsion springs replaced, which may be a good solution if your springs are very old or very rusty.
Posted on Jun 22, 2009
    President:
  • 3,197 Answers
If the door isn't unusually heavy when you open it manually then maybe an adjustment will help. On the back of the motor unit you will find the 'up force' control. Increase it 1/4 turn and try.
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
My craftsman 1/2 hp garage door goes up only about
Release the door from the opener and operate the door by hand. Check the weight of the door. If it is heavy check the door springs. One could be broken. Also take another look at the gear you replaced. Did you use the lubricant on the gear? If not the gear will not last.
Mar 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor humms but door doesn't go up or down!
5 flashes is the code for "RPM sensor board or motor overload." If your door is stuck in the open position the trolley may be jammed against a bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. Now locate the 'up limit' control on the side of the motor unit and turn it a couple turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 376lm Keypad wont work
Reprogram keypad. Press learn button on back of opener, then press in 4-digit code and press and hold enter on keypad. Light on opener will blink.
Dec 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
268 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
