Question about Haier hwr10xc6 Air Conditioner
WILL NOT RESET
IS SOON AS YOU PLUG IT IN TO THE OUTLET THE RESET BUTTON THROWS
  • 32 Answers
You might be plugging it into an ungrounded outlet. Or if you are plugging it into an outlet that has a ground fault interrupter, and it is THAT that is throwing, then you have a short somewhere.
Posted on Jun 21, 2009
The machine has been working well but recently when switched on now trips the whole house safety circuit.
Try plugging something else into the outlet socket to see if that throws the trip fuse. If it does then the outlet is faulty. Try plugging the washer into another outlet and see if it throws the trip in which case the machine is suspect.
Sep 23, 2015 | Washing Machines
My food disposer has no sound I need help. Could you help me?
If you open the cabinet door under the sink, you should be able to see the disposer motor. On the bottom or side, there should be a small bump that is the reset button. Push the button in and it should work again.
If it still does not work, make sure that the power cord is plugged into the outlet.
Still not working? Check the fusebox for a blown fuse or tripped circuit breaker.
One last idea: if the outlet that the disposal is plugged into is a GFCI protected plug, there will be a TEST and RESET button in the center of the outlet. Unplug the disposal cord, press the RESET button on the outlet, then plug the disposal cord back in.
Aug 31, 2015 | Food Mixers
Reset button ac unit
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 26, 2013 | Frigidaire Heating & Cooling
My woods digital timer is acting weird. I take the timer off the outlet and set the timer like normal. The display is doing everything I want it too at this point. But then, as soon as I plug it into...
Copy following link to identify timer and see Woods (Coleman) warranty support link
http://waterheatertimer.org/Woods-timers-and-manuals.html
Buy another timer.
Reset timer using reset button.
Check if timer has batteries. Older timers had batteries. Newer timers have internal rechargeable batteries.
Try on different outlet.
Check outlet polarity using circuit analyzer.
Timers are made to last 1-3 years, some more some less.
Jun 18, 2013 | Hardware & Accessories
Cut cord with mower by accident. connected new cord but no dice. is there a reset button?
Did you check the outlet, you might have tripped the breaker,
or you fried the outlet.
Plug the mower into a outlet that you tested with a lamp or something
so your sure there is power at the outlet, and at the end of the extension cord, if there is power to both but not the mower, contact the company because there is no reset button.
What ever outlet you use to plug this thing into, you should have a ground fault outlet installed, for two reasons, safety for you, and protect the mower.
Feb 05, 2010 | Black & Decker 19" Electric Lawnhog...
My 520 shuts off at 115 psi and throws the reset button
if it throws the reset button when starting back up then the pressure release valve is not unloading the delivery pipe
it should make a loud hissing sound when it cuts out at the set pressure
Dec 12, 2009 | Makita MAC5200 Electric Powered Air...
We have arc fault breakers on our house built in 2002. in trying to plug in our 40'' lcd tv the breaker kicks out as soon as the plug touches the outlet. We've even tried brand new high end TrippLite surge...
Well, considering all TV's these days have what is called a SMPS which means Switch Mode Power Supply. As soon as your plug enters the outlet it will ark, because the power supply starts up immediately, so my suggestion would be is to kill the breaker to that room then plug the set in and then reset the breaker. Let me know how it turns out.
Oct 13, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
When I plug in the unit it trips the reset button every time. Its
This is only a 5,200 BTU unit - for single room use.
If you're sure the voltage ok, it sounds like the unit is new and should be under warranty.
Jul 25, 2009 | Heating & Cooling
Refrigerator keeps throwing receptacle switch plate
I'm assuming this is on a GFCI outlet? May be a problem with the outlet rather than the Fridge. I had an outlet that would do the same thing when it encountered loads. I replaced it and everything was fine.
May 23, 2009 | Kenmore Refrigerators
Haier hwr10xc6 Air Conditioner Logo
213 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
