Question about Kenmore Washing Machines
Kenmore top load washer top agitator not moving
Kenmore washer # 110.92380200. Top agitator not moving (bottom one working just fine), so I went ahead and replaced those dogs as I'd heard I had to do. Problem not fixed. I'm thinking of purchasing the whole agitator repair kit. Will that take care of it? If so, what's the part number of that kit for my washer? Thanks in advance.
  • paulisofi Jun 23, 2009
    Thank God I fixed the darn washer! The problem was that the bearing was missing and so the dogs kept coming out. The job of the bearing is to lock the dogs in place!!! I'm still truly, honestly puzzled at the fact that the machine ran perfectly for 10 years without the bearing! Thanks for your much appreciated input to help me have my washer running fine again!!!
  • 6,784 Answers
HI, this is exactly what you need to eliminate this issue.i will list the part number below. you can click on that number to order the kit directly from the parts store if you wish.
285727
Posted on Jun 21, 2009
  • Michael Masters
    Michael Masters Jun 23, 2009
    Glad to see the washer is running correctly. congrats:)
My washer works fine just no agition goes though cylces just fine fills and drians fine but agitator does not move
80040 dog kit is all you need. The upper portion of the agitator has four dogs mounted inside. As the transmission moves the agitator back and forth these dogs catch the side of the upper agitator. This rotates the fins and makes the clothes tumble on top of each other forcing them into a downward motion. When the facing of the agitator dogs wear smooth the upper agitator will cease to function.
Video:
I have a service manual and more videos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 10, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore model 2495-4301. When closing the lid to begin any cycle, there's a metal clicking sound coming from the area of the bottom. The agitator will not move in any cycle. Just that clicking sound..
I had a similar problem with my washer. It was clicking, but the agitator was moving fine. The clicking was coming from the centrifugal switch. After checking the capacitor I was about the give up and call a repair tech. Then I noticed the Speed Selector was set between Delicate and Normal. I moved the selector to a proper position and the washer stopped making the clicking noise and is working correctly.
Feb 08, 2011 | Kenmore 24952 Top Load Washer
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
Only the bottom agitator works, not the top
replace the dog ears in the upper part of the agitator not expensive and not hard to do ,,,, pop the cap off the upper agitator remove the 7/16 bolt and lift off the upper part and replace the plastic dog ears and reinstall!
Mar 08, 2010 | Kenmore 12502 Top Load Washer
Washer is not rotating fully during wash cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Some Kenmore washers have a two piece agitator. The lower section will rotate back and forth both ways.
The top section has "agitate Dogs" that allow it to rotate only one way (to keep the clothes moving downward.
If yours has a two piece agitator there shouldn't be a problem.
Oct 18, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator: bottom moves, top does not
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
I have a kenmore 110 238 121000
remove agitator cap remove bolt in middle of agitator top section will pull of replace the 4 dogs (slightly off white objects whirlpool part # 80040)
Dec 22, 2008 | Roper RAB2121KW Top Load Washer
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
269 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
