Question about HP PSC 2410 All-In-One InkJet Printer
Same clicking sound, hour glass in display and motor whirring
Same problem as above situation. Never resolves itself, then shuts off.
    Scholar:
  • 169 Answers
That scanner light comes on when I turn on the printer, but it fails to stop at home. Like it is out of time or something. It just keeps clicking the drive motor for the scanner. Have to shut it off to...
For tech guys only: Remove ADF unit, remove control panel bezel, remove flat bed screws & take out flat bed cover(glass), detach CCD cable & belt take out CCD unit, Remove bonnet of CCD you can observe three reflecting glasses fixed in it, clean gently these glasses with ear buds or any smooth cotton carefully.. fix it back, clean flatbed glass in side.. fix unit back & try.. 80% cases resolves with this activity if not resolved replaced CCD unit...
Jul 18, 2012 | HP LaserJet 2840 Printer
Mitsubishi WD-82738 has no picture, makes short whirring sounds but won't turn on. Flashes 6 red lights then 1 yellow light and repeats sequence. Tried system reset but to no avail, light turns green...
After rereading the symptoms you descibe what you describe might be a faulty colorwheel. When the set is first plug up there is a small mechanal motor that has to reach certain speed. if this does not reach that speed the set will not allow the lamp to fire. The whirring sound could be the colorwheel trying to spin up. these break all the time. (its a motor and anything that moves eventally will not.) it a fairly simple rep;air thatn most quilfied techs can repair. Such a repair generally should take more than a hour to do
May 28, 2011 | Televison & Video
My fridge is making a loud clicking noise, and there is no cooling in the fridge or freezer
Hi
First verify that the refrigerator is properly plugged in to a functioning power outlet. Reset the circuit breaker as necessary and avoid plugging the refrigerator in to an extension cord. Turn the thermostat to a colder temperature and wait several hours for the cooler temperature to occur. Note that the refrigerator may take up to 24 hours after its first installation to cool completely and may make several noises, including clicking, during this time. Warm exterior temperatures may also result in the motor running more often than usual. Keep the doors shut as much as possible to allow the internal temperature to cool appropriately. Ensure that the doors are shutting completely and that objects such as food or shelving are not preventing a complete door seal.
Contact service technician for assistance if the above steps do not resolve the problem. Other possible issues may include a broken or malfunctioning motor or thermostat.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 01, 2011 | Refrigerators
2004 focus 80,000 miles/6 weeks ago, using ac with blower on high, blower gradually shut off and car produced bad smell. Drove home with ac off, blower off, had car checked and nothing found. Now it's...
The 'whirring' sound from the blower motor could be a dry bearing or damaged armature (part of blower motor that the brushes ride on), or just wore brushes. The smell could be the motor winding wires burning due to blower motor bogging down and overheating. You can replace blower motor with new or salvaged one.
Dec 09, 2010 | Ford Focus Cars & Trucks
Background changeover unit failure on 6130dj scanner. Tried cleaning it, rebooting pc & downloading driver . . . what else can I do?
When a background switching malfunction occurs, "F" and "4" will display alternately on the function number display panel of the scanner.
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 and check if the problem persists.
If turning on the scanner again does not recover the situation, then follow the procedures provided below:
1 Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2 Are the cables between the Control PCA and the BW Motor damaged? Or are the connectors connected correctly?
3 Is the white reference work properly? If not, then replace the BW Motor.Perform background changeover test.
4 Is the OPT Unit installed correctly? Check ADF (Front) and ADF (Back)
5 Replace the Control PCA and see if the error is resolved.
6 Replace the OPT Unit and see if the error is resolved.
Hope the above information is helpful.
Thanks,
ScanCare
Apr 26, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
The printer is making a gear clicking sound.
I had exactly the same problem with my OfficeJet 6110 as reported above (i.e. the scan head not knowing where the end-stop is). This is how to fix it (this method worked for me) 1) Lift up the scanner/copier hinged lid. Around the edge of the scan glass are 4 Torx screws. Undo all four screws. 2) Carefully prise the control panel faceplate off. The buttons underneath are on a single panel. Slide this to the left and lift off. 3) Jiggle the lid of the scanner to get it off the main body of the printer. 4) Locate the scan engine motor (top right corner) and remove the two motor retaining screws (one on the left of the motor, the other on the right). 5) Lift out the entire mechanism (rod, drive belt, scan head) and turn over. 6) Thoroughly clean all glass and mirrored areas of the scan head. Also clean the scan lamp on the top of the scan head. Clean the tray inside the scanner (where the scan head travels back and forth). Also clean the inside and outside of the scanner glass pane itself. 7) Refit all parts, using the technique described above, in reverse order. 8) Switch on printer. It should now work OK. Hope this helps, guys.
Jun 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
The driver side window on my 1997 pontiac sunfire SE convertible
More than likely it is the window regulator which is usually replaced as a unit with the motor. Not difficult, pull off door panel and plastic liner and see the nuts to remove....about 4. tape glass up to top and pull out regulator...unclip wires. cost $50 to $100. Don't recommmend junkyard because these will be bad. Make sure that you seal plastic liner when reinstalling.
Mar 26, 2009 | 1997 Pontiac Sunfire
On light won't stop blinking and on the display there is an hour glass
there is a pending job queued, unless this file has been released and printed you cannot removed the light from blinking. pls cancell all doc spooled on your pc and select cancell all, press the cancel button on your printer as well then turn off and on your printer
Aug 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
2410 printer will not print
 This is Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue related to the lights blinking and Clicking sound on your Printer. I would like to provide my suggestions on the issue.
This is an issue related to the Printer Carriage stall on your Printer. To resolve the issue, Please try below solutions.
Solution 1:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00299915&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Please open the above link and perform the steps mentioned in the web page.
Oct 22, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
229 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
