Question about Sony VPL-EX1 Multimedia Projector
SOny VPL-EX1 turns on for a few minutes and then the Lamp /Cover LED and Power ON/Standby LED flashes.
Sony VPL-EX1 turns on for a few minutes and then the Lamp /Cover LED and Power ON/Standby LED flashes.
I have cleaned the air filter and also reseated the lamp without any success, if anyone has a solution I would really apprecaite it.
Thxs,
David.
  • 1 more comment
  • krishna186 Apr 01, 2009
    I also have the same problem
    Lamp glows and goes off and lens cover and hight elivator goes down
  • Anonymous Mar 12, 2014
    sony VPL-CX3 lamp reset
  • Anonymous Mar 19, 2014
    hello sir my sony vpl-cs6 giving red lighting to lamp/cover its on continued light so how fix it
  • 563 Answers
Hi David
I think you should replace the lamp.
Posted on Mar 26, 2008
    New Friend:
  • 12 Answers
Do not replase the lamp! check the lamp cover sensor and fan cover sensor its a switch near the exost fan and lamp cap
Posted on Sep 14, 2012
Sony vpl-ex1 doesnt turn on. no light nothihing. power input does work, i can hear it zapping power :). might have dropped from ceiling holder.. atleast it looks like it. im trying to get it work for my...
the filter cover sometimes gets distorted and the small plastic dimple which presses against the switch doesnt activate correctly, check the lamp cover switch also.
Jun 07, 2011 | Sony VPL-EX1 Multimedia Projector
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
Sony VPL-EX3 projector on/off switch flashes green then turns red and the lamp/cover light is orange. Does this mean the lamp needs replacing or could it be caused by some other factors?
Possible that the lamp is faulty -if the hours have elapsed- check the lamp holder, the fitments.
check also the filters, clean and reset.
Make sure the power supply Unit is not having any poor soldering or faulty components to reduce the voltage output to the lamp thus making it shut down..
Jan 17, 2011 | Sony VPL-EX1 Multimedia Projector
I have sony vpl-ex1 projctor and i have also changed the lamp of the projector but it still shows me the same message like change the lamp. Please advice! Thanks, Pravin Bhavsar
1.unplug power cord
2.plug back in and it should be in stand by mode.(red light on)
3.do not power on
4.on remote push RESET,LEFT ARROW,RIGHT ARROW AND ENTER(do it in less than 5 seconds)
5.after you have done this power on and go to menu and it should show lamp hours 0
6.if it didn't work just do it again, it took me a couple of tries.
Jan 04, 2011 | Sony VPL-EX1 Multimedia Projector
Everytime i switch it on it flashes lamp cover even though the cover is not on. Ive switched it off then on again, and the problem still exists
Try replacing the lamp cover with a new one, if that does'nt work then it could be the sencor for the lamp cover, and if that does'nt work then contact your sony dealer and see what they can do.
Feb 09, 2010 | Sony VPL-EX1 Multimedia Projector
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
VPL-EX1 Just bought it from someone the lamp is 450 hours, it worked fine with no message. no im trying to turn it on and it will just lift itself and lamp cover moves but then nothing happens and after a...
I have had the same problem with 3 Sony VPL-EX1s and Sony will not answer emails regarding the problem. Hence I wont be purchasing Sony projectors again.
Apr 01, 2009 | Sony VPL-EX1 Multimedia Projector
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Sony VPL-EX1 Multimedia Projector Logo
1,371 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
