Question about GE Refrigerators
GE refrigerater stops cooling/freezing and restarts?
We have a GE refrigerator in our garage. Approx 5yrs old. Stopped cooling and freezing. Unplugged for a day and plugged back in and in worked for 24 hours, now it is still running but no longer cooling or freezing. Ideas?
  • briar59 Jun 21, 2009
    Is it possible to be in defrost mode when the compressor is cycling in? When in defrost the compressor would not be running correct?
    Sergeant:
  • 212 Answers
Maybe stuck in defrost cycle. usually controlled by a hv board on rear of refrigerator
Posted on Jun 21, 2009
  • kenrick driscoll Jun 21, 2009
    correct. the only thing you will detect on is the lights. during defrost the compressor and fans are in the off position.
    defrost cycle is every 8 to 10 hours. when you unplugged it you reset the controls. when it went back into defrost cycle its not coming back out. if the compressor is running and your still not cooling then your problem will be a sealed system issue. either low on freon or a restriction in the drier.
Kenmore refrigerator freezer stopped freezing and cooling then several hours later started working again ?
Look at what time the defrost timer is set to. It may just be as simple as resetting the time or you may need to replace it .
Aug 04, 2014 | Refrigerators
Replaced relay/overload on GE refrigerator, worked for awhile, then stopped working (and evaporator coil was warm)
Sounds like a bad refrigerator. If less than 5yrs old the sealed system is under warrenty. Call GE service if it is. 1-800-GE Cares
Mar 31, 2012 | GE Refrigerators
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
GE REFRIG. MODEL#TFX30PRYAA. side by side both
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Jul 01, 2009 | Refrigerators
Will not cool proper on fridge side
THIS IS A DEFROST PROBLEM EITHER THE THERMOSTAT OR DEFROST TIMER IS BAD! THE THERMOSTAT IS LOCATED BEHIND THE WALL IN THE FREEZER COMPARTMENT ATTACHED TO THE COILS TO KNOW IF ITS BAD IF WILL HAVE A RAISED SPOT ON THE BACK LIKE ITS BUSTING OPEN CHECK THAT
Apr 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
470 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
