Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
120GB wd external shows up under bios and DM but not my computer
When i connect the hard drive it says that it is connected under the computer bios and under device manager and is working properly with up to date drivers but it will not show an icon under my computer. I tried it on two computers and am getting the same thing. My computers are both running amd processors running at 2.0 ghz with a gig of ram with windows xp pro. If someone could help me i would appreciate it. Thank you.
  • 50 Answers
It seems as if the drive is damaged.
To see if you can just erase the partition on it, recreate it and see if that works:
Right click on "My Computer", go to "Manage", then Disk Management. You'll probably find the external drive in the list there.
Delete the partition you see, and recreate it from the same menu. Format the partition you just created, all through the same menu.
Hope I helped,
tom
Posted on Jun 21, 2009
  • 1,959 Answers
Assuming both PC's have SP3 installed there's a registry patch Windows put out to address the problem you're experiencing. Here is a link to the fix. Hopefully, this will solve your problem. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Computer will boot up with the external hard drive connected
if u dont want to bootup with external HD goto bios under boot device property first boot for {make it system intarnal HD}
Jun 26, 2010 | Maxtor OneTouch III Mini Edition 120GB...
My computer hangs when I start it up until I remove the WD 320 GB External USB connection - then it will restart ok. I have to then reconnect the hd. - what can I do about this?
It sounds like it is trying to boot from the external drive, go into the BIOS settings and disable boot from external device and see if that cures it.
Mar 30, 2010 | Western Digital Elements powered by WD 320...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
Hi, my WD hard drive is connected to my macbook, but can't access
check under the system profiler which can be found in the applications folder and then in the utilities folder. See if under usb whether the drive is showing under there. If it is, open up disk utility and use the verify disk to see if there is a problem with the drive, if there is use the repair disk to repair it.
Other things to check try a different usb port on the macbook or a different usb cable.
Hope this helps
Oct 21, 2009 | Western Digital 250GB MyBook External USB...
External Hard Drive connected but hidden !!!
Connect it to your computer.
Right click on my computer and select Manage
On the left side click on Disk management.
Now on the right side, look around and see if you spot the external drive there.
What do you see there?
Also look into device manager, then look for anything with ! or ? yellow marks.
May 03, 2009 | Western Digital WD Passport 250GB Portable...
USB ports on my laptop and others wont recognize my 320GB Passpor
ok
go to your computer bios setup .
U can go to bios with "del" or F@ oe any key for enter in bios setup then go to usb configuration then set high speed and legacy 2.0 enabled then save alls ettings .
May 03, 2009 | Seagate Snow Translucent...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
184 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
