Question about Lexmark X658DE All-In-One Laser Printer
How do I factory reset a Lexmark x658de?
I need to completely reset this printer to the defaults. We've lost the admin username and password and cant' change the IP/Domain details.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 127 Answers
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Posted on May 03, 2014
SOURCE:
Nic61
  • 1073 Answers
SOURCE: Reset Lexmark E250dn IP address
Yes you can, but you need to lock that ip in your router to so its always goes to your printer.
Just make sure that your router dosent use that ip for it self, the usal ip for a router is 192.168.0.0 or 192.168.0.1, but you never know. Check it to be shure!
Posted on Dec 18, 2008
JohnGJohn
  • 215 Answers
SOURCE: I would like to know how to reset the Lexmark
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
Posted on Oct 01, 2009
  • 77 Answers
SOURCE: Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Posted on Sep 08, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark x9575 all in one
    Try to unplug the power adapter from the printer. Then unplug and replug the power cord into the power outlet. Replug the power adapter into the printer. This will help reset the printer. Check if problem continues.
    Posted on Jun 01, 2011
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: What is the standard web username and password? How can i reset the printer to factory defaults?
      Please refer to this article from the Lexmark website about How to Reset the Z1400 and Z1500 Series Network Settings.
      I hope this helps.
      Posted on Mar 15, 2012
      I have a trendnet tew-625brp, i just opened it, i can connect to it perfectly by cable howeve i want to set it up wirelessly, when i go to 192.168.10.1, i type in admin for username and password, and it...
      You must complete the setup with a wired connection. Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
      Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
      Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
      D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
      Encore - Username: admin Password: admin Default IP address 192.168.1.1
      Linksys - Username: admin Password: admin Default IP address 192.168.1.1
      NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
      TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
      TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
      Zhone - Username: admin Password: admin Default IP address 192.168.1.1
      Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
      Sep 07, 2011 | Computers & Internet
      Forgot my password and cannot reset?
      Sep 06, 2011 | Computers & Internet
      I lost my password to my dir-601 router and need it for an Ipod to run of my wireless net. How can I find it? I have the security code. Thanks
      You have several options. However, I'm unsure if you have lost the username/password to access your D-Link router's setup/configuration page or if you have lost your wireless access code (used to access your wireless internet).
      If you have lost your username/password to your routers setup/configuration page first try the factory default combination.
      The default username is: admin
      The default password leave blank
      If you have customized the username and password during the original install you will have to reset the router to its factory default settings. To do this:
      PLEASE NOT THAT BY DOING THIS YOUR ROUTER WILL BE RESET TO FACTORY DEFAULT AND WILL HAVE TO BE RECONFIGURED
      Locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a
      paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
      Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is: admin and leave the password box empty.
      Please let me know if I can assist you further.
      Regards,
      KYTechnology
      Feb 28, 2011 | D-Link Computers & Internet
      Lost password
      •Connect the power cord
      •Unplug ALL Ethernet connections
      •Hold down the reset button for at least 15 seconds
      This will reset your router to factory defaults. •Open Internet Explorer (with the computer connected to the Router)•Enter 192.168.1.1 into the Address Bar, push Enter•If 192.168.1.1 does not appear to work, try 192.168.0.1•Under the Username field enter "admin"•Under the password field enter "password"•Click "OK"
      Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
      Dec 05, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
      Lost my key password for belkin g router
      there is a small reset button that u will need to push with a pen. Its usually to the back or side of the router.
      Just jeep pushing it until the router resets then use the default username and password.
      defaults. (normally)
      user name - admin
      password - admin
      username - Admin
      password - admin
      username Admin
      password Admin
      user name Admin
      password (blank)
      username admin
      password blank
      look in your manual for the default username and password and instructions on how to reset.
      Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
      How to recover a lost password on a Nortel SR 1004
      There's no way that you can restore a lost password of your router. The only way you can do is to reset it to factory default and you must know the default username and password of your router. Some of the router manufacturers uses: admin for username and pass for password, some just leaves the password blank but put admin for the username.
      Jan 05, 2010 | Nortel Secure Router 1004
      Lost Password
      If you reset the router to factory defaults, then it SHOULDN'T have a password anymore, and if it does, it's probably something like:
      Username : Admin
      Password : Admin
      or something like that, actually, it should just be blank. Try checking it's manual, as it may give the factory default username and password in there.
      Jul 05, 2009 | Computers & Internet
      Lost password for wireless connection
      Reset your router using the reset button. That will put everything back to factory settings.
      Dec 25, 2007 | Broadcom BCM5705 Network Adapter
      Factory default
      The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
      Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
      Factory default
      Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
      Lexmark X658DE All-In-One Laser Printer Logo
      2,152 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Clive
      Clive
      Thomas F. Schneider
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
