Question about Lenovo ThinkPad T61 Notebook
Removal of betzel
How do you remove the betzel so as to get to the inverter??
  • 439 Answers
On your bezel you will see rubber stops. Peel these off using a small flathead screwdriver. Under these you will find small standard screws that need to be removed. After that using the small flathead, gently pry the bezel away from the screen. Do this slowly and gently as you could possibly break the bezel during removal. Once removed the inverter will me at the bottom center of the screen.
Posted on Jun 21, 2009
Flickering
Step 1:
An inverter is an electrical device on the bottom of your laptop screen. The job of the inverter is to convert DC electrical current to AC voltage to maintain power to the backlight lamp. If the display on your laptop is dark but working, odds are the inverter or the lamp are at fault. When troubleshooting monitor problems on a laptop, you may need to evaluate the inverter to determine which of the two parts is malfunctioning.
Remove the screen bezel on your laptop. The bezel is the piece of the computer casing that surrounds and protects the LCD screen. To remove the bezel, remove the screws around the screen. Bezel removal method may vary by model. Once the screws come out, the bezel should pop off. The inverter will be under the screen. Attach the positive probe (+) of a multimeter to the pin 1 on the inverter. The inverter has two connections, one on each end. With the laptop screen facing you, look at the left side of the inverter. Pin 1 is the top metal flange pointing to the right. Secure the negative probe (-) of the multimeter to any bare screw. There should be a screw securing the inverter to the laptop that will be perfect for the negative ground connection. Turn the laptop on to test the inverter. Turn the multimeter on and check the multimeter reading. If the display records voltage going to the inverter, such as 19 V DC, the inverter power supply is working. Turn the laptop off. Unplug the LCD inverter connection on the right side of the inverter. This disconnects the backlight from the inverter. Plug a working backlight to the connection on the right side of the inverter. Turn on the laptop. If the screen lights up, the backlight lamp is bad but the inverter works. If the screen remains dark, the inverter is bad.
b>
Feb 24, 2013 | Computers & Internet
Hp 6735sscreen does not come on
Step 1:
Feb 24, 2013 | HP Compaq 6735s Notebook
Screen flickers laptop
Step 1:
Feb 23, 2013 | Computers & Internet
My screen jumps and is full of lines
Step 1:
Feb 22, 2013 | Dell Inspiron Mini 10v Netbook
I would like to install a new inverter how do I do it please?
  1. Remove Battery
  2. Remove Power adapter
  3. Lay laptop out flat
  4. Remove screws holding frame around screen in place ( there are usually 6 screws -- 2 at the bottom / 4 at the top / they usually covered with rubber dots )
  5. Carefully unsnap plastic frame
  6. inverter is located between hinges / carefully remove cables from board
  7. Install replacement inverter / reassemble in reverse order
Feb 16, 2011 | Computers & Internet
How do I remove the invertor from a Qosmio F20?
The inverter is located behind the bezel at the bottom of the screen/lid and in between the hinges.
The bezel has screws that fixes it to the lid and these can be hidden by stick-on plastic covers. Use a thin sharp point to lift these plastic covers off to reveal the screws. Remove these screws.
The bezel has small plastic catches that clips it to the lid and may also be fixed to the LCD screen with double sided tape. Use a thin blade and insert it between the LCD screen and the bezel and gently ease the bezel off. Start at the bottom of the screen and gradually work along the edge and continue around each side to free the bezel.
Be CAREFUL not to scratch the LCD screen and DO NOT apply too much pressure to the face of the LCD screen because you can crack the glass surface and ruin the LCD screen.
Once the bezel is removed then you can get access to the inverter to remove it.
Nov 16, 2009 | Toshiba Qosmio G15 Notebook
Hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Nov 17, 2008 | HP Pavilion zd8000 Notebook
Amilo Pro V2010 base removal
Hi
The inverter is in the laptop screen, not the base.
1 remove the screw covers and then the screws surrounding the laptop screen
2 gently prise the screen bezel away from the screen, best done when the laptop is opened out almost flat
3 the inverter is at the base of the screen, gently unscrew and unclip the inverter from the LCD screen
4 take replacing the inverter to make sure all the leads are safely housed
5 replace screen bezel and away you go
Oct 11, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Backlight Inverter.
In my experience, the inverter is usually located at the very bottom of the display assembly (nearest where the hinges connect). You'll have to remove the bezel from the display to access the inverter board. Refer to pages 121-125 of this assembly manual. It doesn't discuss the inverter board directly, only how to remove the display (if you haven't already). The bezel on the display may have a few screws (behind rubber pads, usually), but the rest of the bezel should pop apart.
Mar 11, 2008 | Compaq Presario M2000 Notebook
Lenovo ThinkPad T61 Notebook Logo
210 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
