Question about Amana ABB2227DE Bottom Freezer Refrigerator
Amana ABB2227DES leaking
Leaks from the bottom with puddles of water on the floor
  • 76 Answers
SOURCE: freezer leaks water!
luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
Posted on Dec 22, 2006
  • 8 Answers
SOURCE: water leaking from bottom of side by side refrigerator
The is a fairly easy way if you have a strong stomach.
On the back of the refrigerator, you will see a plastic drain line running to a pan underneath the box. This is the drain line for the evaporator condensate water. It is stopped up in the refrigerator section of the box.
Here is the tough part...Pull the hose out of the back until you can wipe it off with a clean towel and blow hard through the hose with your mouth.
By the way ...take your food out of the fridge...you will blow some pretty disgusting stuff out of the drain and into your desert if you don't. This will cure your leak.
Pssst...you can used compressed air if you are a wuss! lol
Good luck
Posted on Jun 10, 2008
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
SOURCE: bottom freezer is leaking water. Water seems to
You have a clogged defrost drain. The problem is fixed by unplugging unit from wall, open both doors, blow fan for 24 hours to SAFELY remove the ice covering the drain hole. If you use ANY other method, you may regret it. Once ice is melted, remove debris that is likely blocking the small drain hole, if no debris in drain pan, direct some high pressure air down the drain to block the debris INSIDE the tubing. Furthermore, its a good idea to make the drain hole in the drain pan larger, as sometimes a bubble of water can freeze in the drain hole, and ice could be the cause of your blockage from that bubble.
Posted on Jun 28, 2010
My bottom mounted freezer continues to freeze up and leaks a small puddle on the floor
You have a drain hole behind the rear wall of the freezer compartment. You will need to remove the shelves, screws and clean the hole of ice and gunk. here is a video below.
Leaking Refrigerators Leaking Refrigerators
Appliance 911 Sea Breeze
Aug 02, 2015 | Refrigerators
Amana side by side refrigerator dumps a large puddle of water in front every month or so. Nothing in the owner's manual to help trouble shoot this problem. Model is SS25TE
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,
there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 07, 2011 | Amana Refrigerators
Our amana bottom freezer refrigerator Model ABB2224DEQ at times leaks onto our kitchen floor. We don't have an ice maker so I am wondering where it would be coming from and what needs to be done to...
This is likely water from the auto defrost operation leaking from the evaporating pan. Sounds like the pan may have a hole in it, or the hose which drains the water into the pan is leaking, The pan is at the very bottom of the unit.
Charlie
Mar 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana bottom freezer model ABB2227DES--food in fridge is freezing when it didn't before.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Amana ABB2227DE Bottom Freezer...
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Amana ABB2227DE Bottom Freezer Refrigerator Logo
88 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
