Question about Jensen TS2050J 20" TV
Lost green color in picture
I've lost the green color in my picture. I know very little but what I do know is that there are 3 "guns" that incorporate red, blue and green in order to give the TV color. I assume that whatever shoots the green, or the circuit board or power supply to the circuit board that shoots the green, needs to be replaced. I want to perform the work myself. How do I start?
  • 4 more comments
  • Elieng Nov 06, 2007
    Thanks. I will do that. I borrowed some books from the library and found that there is a single chip that takes care of the color, among other things. I don't own an oscilloscope so I can't check for a proper square wave or for the 3.58-MHz the crystal is supposed to put out. Can I just change out the entire IC or is there some output that the color output transistors should put out that I can check with a digital multimeter? Meanwhile where can I find a manual to download for my specific TV? Thanks.
  • Elieng Nov 07, 2007
    I've figured out that rather than replace the chip I should replace the CRT board. The problem is I can't find a service manual. Any ideas, please?
  • Elieng Nov 11, 2007
    Okay. No luck with the mauals. I can't find one anywhere on-line. Let's try a different approach. Is changing the entire board attached to the CRT difficult? Are they expensive? I figure it's easier to change out the entire board then the chip that controls color output. I would likely destroy the traces or vias and wind up having to replace the board anyway. Please, someone give me some direction. My wife will only tolerate the TV sitting in the living room floor for only a little while longer before she claims victory that men are always claiming to be able to fix stuff when they actually can't and are just avoiding the inevitable that a new purchase must be made. Help me fight the good fight, here. Signed, man-in-trouble.
    Thank you. I'm going to finally open up the TV tomorrow and swap the transistors around, as you suggested. Then, depending on what happens I will likely replace all three as a precaution. I'll let you know how it turns out. I have a bet with my wife riding on being able to repair the TV. Wish me luck.
    I'd like to give credit to both SparkGap and Benimur as they have both been helpful.
    SparkGap- It's not that I doubted you, man, I just lost patience and did not go the extra "click" that would've taken me to the manual.
    Benimur,
    I checked the output at the pin on the neckboard end of the cable connecting the neck board to the main board and found the Gy output to be only 700 mV while the By and Ry were both at 2.5 V. I then followed the cable to the IC and found the output there at the Gy to also be only 700 mV. My last check will be at the input pin corresponding to the Gy output to see if the problem is before the IC. In any event I don't own the sophisticated soldering gear to desolder any of these components without messing up the traces. I will likely by a new TV. But thanks to you guys for all your help. That includes Poohawk as well. Thanks.
  • Anonymous Mar 30, 2014
    I have 3 nv65ah siding guns that seem to try to shoot 2 nails at once. one goes part way into board the other gets jammed beside the driver pin and hangs the gun up. any idea where I should start replacing parts?
    Brigadier General:
  • 6,966 Answers
If I may add to the posts of SparkGap and Poohawk
Have not worked on any Jensen models since they are not available in my region, but your problem seems to be typical in most CRT models either TV or monitors.
Most models/version would have 3 transistors for the color drive in the CRT PCB. In some cases, it would be a single power IC block. Assuming yours is the transistor variety, you simply have to replace 1 of the three. These transistors are easy to recognize since they are the largest in the CRT PCB and would often be attached to a heatsink. Alternately, it is also possible that you simply have a cold solder problem. Some would exhibit good passive test (forward/reverse bias test with an Ohmeter) but would fail when active. A sure test is to simply swap the red, green and blue power transistors around. The missing color would be a different color now other than green if indeed 1 of the 3 fails when powered. In some extreme cases it is the collector resistor (normally 1 watt) that also fails. Should you be able to identify/determine which of the 3, you can purchase a replacement transistor or play it safe and simply replace the 3. I would expect that the cost of the 3 transistors would be less than the CRT board and perhaps more easily replaceable.
Hope this be of further help to you. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 11, 2007
    Sergeant:
  • 324 Answers
Follow the following link. It isn't free, but it is the service manual.
Best of luck.
R-
Posted on Nov 07, 2007
  • Ron Roske Nov 07, 2007
    Oops! forgot to put the link in the last message. Let's try that again!
    http://www.servicemanuals.net/service.as...
    R-
    My apologies to both of you. Should have had a second cup of coffee before I posted that. You couldn't find it there, cause it wasn't there. Think that I'll go over in the corner and pout for awhile.
    Hope you guys have a better day than I am...
    R-
  • 363 Answers
I would start by obtaining the service manual. It will have circuit diagrams and diagnostic procedures.
Posted on Nov 04, 2007
  • 2 more comments
  • Martin B
    Martin B Nov 07, 2007
    Yes, difficult finding anything Jensen TV related!
    I'm under the impression that Jensen is Hitachi rebranded in which case:-
    http://www.manualuniverse.com/manager/pr...
    Otherwise the only way may be to contact PWW, they support TV's from Jensen http://www.pwwservice.com/main.htm
    Wish I could be more help, but I did search all my usual places and more.
  • Martin B
    I couldn't find it at servicemanuals.net, where was it Poo?
  • Martin B
    Sorry the posted hyperlink didn't work you have to click http://www.manualuniverse.com/ go to catalogue and search for Hitachi TS2050J.
    Good luck
  • Martin B
    Martin B Nov 11, 2007
    The manual is definitely available from Manual universe.
    Short of actually putting it in the cart to prove the point, heres a screenshot.
    You click TS2050 result after the search. It's not clear admittedly.
Have gone from a good picture to green and blue picture.what happened?
Hi:
If you are connecting the unit by componet cables (RED,GREEN<BLUE) check the cables first to make sure all are connected. If you find they are ok then your red tube may not be lighting up. If you are using a cable box try connectioning the set direct to the cable outlet on your wall. You could also be missing red drive signal to the CRT, in which case service is needed.
Mar 10, 2011 | Samsung Televison & Video
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My sony tv picture is showing green color. What is the problem
U have 3 color guns in a picture tube. One of your guns are not working properly. Too costly to replace. sorry.
May 19, 2010 | Home Security
I have sound but the picture is purple and will not adjust with the remote or manually with the buttons on the tv what can I do to fix this on the philips 36pt41b129
The unit has lost its green video information. This can be a picture tube or a green drive problem. The only colors you are getting are red and blue thus the purple picture. All picture tubes have red, green and blue guns to make all the colors needed for a normal picture. It will take some troubleshooting to determine whether it is a drive problem or the picture tube itself. Have a repair shop check it out for you. A 36" TV is worth a check out fee. Thanks for using Fixya. Let me know how it goes.
Nov 05, 2009 | Philips Televison & Video
The monitor has now got a blue tint I have checked the lead
Your monitor has a menu system that will allow you to access the color guns so you can adjust the red, blue, green guns that create the color picture.
The blue tint may indicate that you need to adjust teh reg and green to offset OR it may indicate that you have lost the red gun all together.
If this is an older monitor and you are considering repair... cost points say it is cheaper to buy a monitor ~$60 bucks
Oct 03, 2009 | Computers & Internet
The picture comes in good except that the colors red,pink and blue has become real dominant I tried to adjust the color but those 3 colors reall show through
Hitachi was know for their problems with picture tub sets. Every time is was the main the board was bad that was control green gun.
Aug 12, 2009 | Hitachi Televison & Video
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Too much red color in the picture
SOUNDS LIKE U HAVE LOST THE GREEN OR BLUE COLOR GUN
Aug 27, 2008 | Hitachi 51G500 51" Rear Projection...
Dominant blue
Can you post to the party who has too much green how to adjust the video adjustments? They need to know so they can see if
its just a simple adjustment.
In your case, first turn the color level clear down to where you
have a black and white picture. As in the case of too much green,
question is if the picture is black and white or if there is a color
on the screen so its blue and white? I suspect it will be which
is typical when the guns start to fail. Likely the green and red
guns are weak in output. There are screen adjustments in the set that a tech can set up that may help some, but the only real fix is to replace the guns which is expensive and requires a complete allignment. All 3 guns need changing to get it back to spec and it is a good idea to replace the flyback for reliability. Get an estimate and likely you can replace the set for the same money.
Jul 26, 2008 | Mitsubishi CS-27205 TV
Jensen TS2050J 20" TV Logo
55 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
