Question about Epson Expression 1680 Professional Flatbed Scanner
Epson 1680 Scanner. "Error" light and "Ready" light both blinking
I get a communication error box on the screen when I try to scan. Both "error" and "ready" lights are blinking. I have tried restarting both computer and scanner, and also unplugging and replugging scanner cord to and from computer with no change.
Suggestions?
4 Suggested Answers
SOURCE: Ready/Error Light
IT have just been down to look at our scanner & cleaned the sensor which is in between the rollers just where the paper flits out at the bottom - we now have a green light! So look for that sensor.
Posted on Jan 29, 2008
SOURCE: Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Posted on Mar 06, 2008
SOURCE: UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Posted on Mar 20, 2010
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
General error with epson tx111
mw tanya saya punya epson TX111 gimana cara mengatasi general error ketiga lampunya nyala bersama sama..mohon bantuannya...
Oct 10, 2010 | Epson Office Equipment & Supplies
Getting blinking "red light" , doesn't scan
There are a few reasons this might happen. 1) Check if the transport lock is in the locked position. Unlock the unit if it is locked.
2) An error occurred. Try restarting the computer, unplug the scanner, wait 10 seconds and reconnect the scanner. (This fixes issues where the software isn't running/fully loaded or the connection isn't solid).
Try a new USB cable and a different port. If you have a USB hub in the middle, try a direct connection. (Bi-directional communication is needed and this may show as an error if it is lost.)
3) Try unplugging the scanner from power and plugging it back in.
4) Try unplugging the optional accessories. If they fail, the unit may indicate a failure.
5) The lamp may need to be replaced.
6) Something else may have failed. Consider if it is worth having the unit serviced.
I hope one of these ideas helps.
May 16, 2010 | Epson Perfection 3490 PHOTO Flatbed...
My Epson CX3900 prints fine. It's when I try to open Epson scan that I get an error message "Cannot properly communicate with scanner"
if the unit is directly connected via USB, another program or prev installed scanner software is using "the path" to communicate with the scanner. Can only use one scanner at a time with windows.
Nov 25, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
Communication with scanner
You could take it apart and see if you can lubricate the shaft the the scanner sits on with some vasoline. If that doesn't it could be that the stepper motor that controls the scanner is going bad in it.
Jul 18, 2008 | Epson Expression 1680 Professional Flatbed...
SCAN STOPS MIDWAY
Are you getting an error/ red light on the scanner button when its on? when scanning from Paint ( File, then from scanners and cameras) does it freeze as well? or only when using epson scan? make sure cable is directly connected from the scanner to your computer, no hubs or anything.. keep me posted.
Have a nice day!!
Jun 12, 2008 | Epson Perfection 4990 Flatbed Scanner
Transparency adaptor won't close
Remove the transparency adaptor from the scanner bed (unscrew the two smaller screws, then slide back and off) and then remove the glass (and plastic frame) of the transparency adapter (there are six screws).
By the hinge there is a small white plastic switch. Usually the transparency adaptor hits this when it's closed, letting your computer know that it is ready to scan. What I did, as bcvideo did, was take duct tape and firmly taped the switch to the side of the transparency adaptor, using several small strips of tape.
The scanner works well now. You may need/want to put something on top of the scanner if it does not fully close.
Apr 08, 2008 | Epson Expression 1680 Professional Flatbed...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Expression 1680 Professional Flatbed Scanner Logo
170 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
