Question about Fedders Heating & Cooling
Fedders CH1036BBD1V not comming on. Is there a reset button?
My Mom has a Fedders Window Air Conditioner Model # A7T12F2A Serial # CP961286 075E
Switch off, press reset and switch back on. Keep reset pressed for 10 secs. Check the bit behind the filter is also clean and check the drain isn't clogged.
May 16, 2012 | Fedders Heating & Cooling
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
The reset button that came on the cord of my Fedders model AED24E7F-C keeps tripping after a short while. Otherwise the unit blows cold and works fine. I can hit the off button when it is working fine...
Do you have anything else on the same circuit? I have heard about many of these units, not just Fedders, that will not run on a circuit that has another appliance or something that is pulling a lot of amperage. Also, check and make sure the receptacle is not worn and the plug is loose fitting. Other wise, you definitely could have a weak internal connection in the cord. Hope this helps.
Jun 28, 2011 | Fedders AED24E7F Wall/Window Air...
Fedders window ac was running control lights started going on and off ac went on and off then quit power supply is fine. reset does no good
assuming that you have a reset button on the power cord and after pushing the button you dont hear a beeping sound, there's the possibility that your cord is defective. Check it with a volt metter at the end of the terminals.
Sep 23, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Does not start, manual nor remote
found fedders is bankrupt and another company is using the name
the tech there told me about the reset button on the other side of the plug, and the reset button worked
thanks
ALAN
Feb 11, 2009 | Fedders A6Y12F2B Y Chassis Room Air...
Fedders window model A6Y12F2B "New Unit",,only 10 days in use! Just stopped working No Power To Master Panel Air Conditioner Not Working Fuse Panel/Breaker ok,Outlet ok,,power to plug...
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Jun 22, 2008 | Fedders Heating & Cooling
Heating & Cooling Logo
266 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
