Question about Dell Inspiron 9200 Notebook
Battery will not charge on my 9200 inspiron
Just bought a new battery and still will not charge says battery is idle
  • 439 Answers
It is a problem with your computers battery connector. If your computer is under warranty you should send it in, if not you will want to look into replacing the receptical.
Posted on Jun 21, 2009
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
New aftermarket Inspiron 6000 battery will not power the Laptop
I would say that the power management portion of the system board is probably faulty if it behaves the same with both the factory battery and the aftermarket.
Many systems have the charge controller and battery interface on a separate board but unfortunately on the Inspiron 6000 it's integrated.
FYI, Here's a copy of the service manual for that system: http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Jan 21, 2010 | Dell Inspiron 6000 Notebook
New dell replacement battery wont charge insp 9200
Sounds like it is a bad battery - do you know if it was working before you purchased it? Could the pins between the battery and laptop be misaligned? I had this once and i had to get a new system board.
Jun 27, 2009 | Dell Inspiron 9200 Notebook
My dell Inspiron 9200 won't power on - I have replaced the adaptor, but it won't show that it is charging and won't turn on. Should I bite the bullet and buy a new battery - If so, do the generic ones...
if you are not seeing a charge light when you plug in your charger, the problem is not in the battery. If you have (as you say) replaced the charger, then the problem is not there either.
That leaves one place: the power jack.
It is common for laptops to experience failure at this point. Some laptop manufacturers have even made this a replacable part, allowing a technician to simply unplug the old one and plug in the new one.
Most, however, are soldered to the motherboard and the repair is more compllicated.
As for the batteries, the cell count is the primary feature to watch for battery function. 6 cell batteries are more common now and hold the charge longer. Compare this feature when choosing a battery.
however, the jack is most likely your problem.
good luck
tony
Jun 06, 2009 | Dell Inspiron E1705 Notebook
Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Mar 11, 2009 | Dell Latitude D600 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 9200 Battery defunct or ....
Try taking the battery out of the laptop, and see if it will power up. If not it is possible that your power cord died - and your battery may be just fine.
For reference, I've seen plenty of Dell's with dead power cables.
Jan 27, 2008 | Dell Inspiron 9200 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron 9200 Notebook Logo
153 people viewed this question
Alun Cox
