You have not given enough information to make a proper diagnosis. The first thing to check is if the bottom bass speaker is working when the top speaker goes out. If it is then you can easily check the top speaker by jumpering from the working speaker to the one not working. Odds are it is not the speaker. It could be amp connections as the other guy suggested but then you should not have sound from the bottom speaker either. You can wiggle the connection after the sound goes out and listen for it to come back to check for a cold solder joint.
Other possibilities, if both speakers are out, swap the right and left inputs to the amp. Does the sound switch sides? If so it is a signal line problem in the player or the decoder. I have found the decoders to be loaded with cold solder joints but this is not work for amateurs. Check the door speaker connections. Check that the RCA plugs are firmly attached to the decoder board. Check the connections on the output transformers, are the tight? There are other things as well but this might help
You could have connector problems on the speaker crossover network located inside the amplifier compartment on the opposite wall from the amplifier. Typically the solder joints go bad where the connectors are soldered to the board. Usually a simple resoldering can fix it. There could also be problems with the connectors at that particular speaker itself.
SOURCE: Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
SOURCE: Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
I checked connections inside amplifier compartment and some were loose. Thank you.
