Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1995 chevy pickup ignition engages but starter doesn't seem to turn engine over and winds down. I turn key over again and it works fine, what is causing this problem?
Your starter is slowly dying, have it rebuilt or replace it.
Posted on Jul 09, 2009
    President:
  • Chevrolet Master
  • 1,564 Answers
General motors starters do a thing called "fielding" When the rear bearing or front bearing wear out, the armature windings actually come in contact with the magnetic field. This gennerally occurs "after" the vehicle is warmed up. It will progress to a point where the starte will not operate at all. Once you've determined the battery and charging system are okay then it's time to replace the starter. Let me know if this is helpful.
Posted on Jul 27, 2009
90% of electrical problems of not starting, or slow operation one needs to (wear eye protection, and
vinyl, rubber, or latex gloves, wash your hands when your done, have key off, no fuels
open nearby,) Locate car battery. If you are not at all handy with tools , you should
not attempt this work. The two Posts on the battery are always getting dirty and
corroded and slowing or stopping the 12.60 volts Direct Current within a 100% charged
up battery from conducting by clean, tight contact with the inside of the battery cables
clamped/bolted generally to the battery. Cleaning that connection is the lst, and
highest pay-off operation. One BIG check before mechanically cleaning that
battery to cable connection is: IS THE BATTERY AT FULL CHARGE?
A MULTIMETER (ABOUT $10-15 @ SEARS), OR GO SEE IF HEADLIGHTS COME
ON WHEN YOU PULL ON THE LIGHTS, IF LIGHTS LOOK WEAK/DIM
NOT BRIGHT, THEN, HEY YA GOTTA GET THE BATTERY CHARGED-UP
FIRST. The Meter really tells the truth about the batteries STATE-OF-CHARGE.
The quick check of looking to see if lights come on is dependent on the cable
connections being clean, keep that in mind. Don't forget to TURN THE LIGHTS
OFF.
Be Safe , If your going to unclamp a battery cable and clean it GET AN ADULT,
SOBER, WHO KNOWS HOW TO USE TOOLS , OK? WHY?
THE 12 VOLTS IN THE BATTERY WANTS TO MOVE AT THE SPEED OF
LIGHT TO WHATEVER METAL NEAR IT, OR BROUGHT CLOSE TO IT.
IF YOUR METAL TOOL, FOR ANY MICRO-SPECK OF TIME CREATES
A CONNECTION TO METAL AND ONE IS BATTERY (+) POSITIVE, AND
THE OTHER IS BATTERY (-)NEGATIVE (FOR EXAMPLE THE (+)
POST ON THE BATTERY AND THE CARS METAL PARTS, (PAINTED OR
BARE METAL, NO MATTER), THEN BIG SPARK, TOOL HEATS TO
CHERRY-RED IN SECONDS, WELDS ITSELF ELECTRICALLY IN
WHATEVER POSITION IT CONTACTS THE METAL ONE TOUCHED WITH
ANY PORTION OF THE TOOL. FIRE ENSUES. USE ELECTRICAL
FIRE TYPE FIRE EXTINGUISHER, CALL 911, STAY BACK, GET
KIDS AWAY. GET BACK A CITY-BLOCK. NEVER WORK ON CARS
AGAIN. SOME OF US JUST DON'T LISTEN TO WARNINGS, AND
REALLY SOME KIDS DON 'T KNOW HOW TO READ, ADULTS TOOL
HABLA ESPANOL? SI NO BIEN ENTENDER USO DE HERRAMIENTAS
BUSCAN UN PERSONA CON MUCHO MAS EXPERIENCA ARREGLANDO
automoviles. (can't tell how much of that is misspelled)
BOTTOM LINE; NOT Having ANY idea whom is the audience , and the
BIG TROUBLE a innocent , would be heading for this
explanation stops here. KIDS AND NON-SERIOUS ADULTS
SHOULD HAVE SOMEONE KNOWLEGE-ABLE DO
ANY WORK WITH METAL ANYTHING AROUND AUTO
BATTERIES.
Posted on Jul 26, 2009
Eaither destributer cap might b loose if you have a coil ignition u might want to change that to a msd or to light rob coil...or it could simply be the coil on the actual starter some times the only have enough juice for the electronices and not so much for the cranking over
Posted on Jun 24, 2009
Hei gm ignition i have power to stater but thats wear it ends had starter tested in good working order replaced nuetral safety switch ignition switch put new ignition coil also still no power
No power where ? What happen's when you turn the key to the start position ? Does the starter engage an spin the engine ? Need to give better info.
Nov 22, 2017 | Cars & Trucks
Replaced my fuel pump on my Chevy 1500 pickup truck but won't start wut am I doing wrong
I will assume the engine is turning over. Are you getting fuel up to the fuel rail? When you turn the key on, but not to start, do you hear the fuel pump hum for a moment before it turns off?
Have you checked all the fuses?
Jan 08, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
Wont start
could be switch on back of ignition lock?
Jul 09, 2009 | Chevrolet 1500 Cars & Trucks
Starter replacement......needs to know how many cylinders my cars has
The starter has no cylinders. it is an electric motor powered from the battery and ignition system.
The chevy cavalier has a 4 cylinder engine though.
Jun 02, 2009 | 1992 Chevrolet Cavalier
1999 FORD EXPEDITION intermittantly will not start.
You have a bad starter. A faulty starter will function when its cold but when it heats up, it takes more energy to get the starter to engage. Your problem is exhibiting the classic symptoms of a bad starter. I hope this solves your problem and the best of luck to you.
May 11, 2009 | 1999 Ford Expedition
My 95 chevy camaro starting issue
sounds like its the ignition switch.the grinding noise you hear is probably the starter still engaged. thanks jeff
Nov 30, 2008 | 1995 Chevrolet Camaro
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
759 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
