Question about Microsoft Windows Vista Ultimate Edition
Will not connect someplaces
I cannot get wifi at some hotels wiith vista now.
  • 306 Answers
Re: will not connect someplaces
Does it give you an Error of some sort, Need more details.
Can you open: Connect to.? Does it list any devices?
What happens when you try to connect to them?
Posted on Nov 10, 2007
0 characters
3 Points
Wireless association failed due unknown reason
There's always a reason but who cares if there is a good solution. Try rebooting your wifi router and then your PC and see if the connection returns. Also try to delete your WIFI network connection. Then reboot and it should return and so may your connection! If its a secure connection check if your password is correct by opening your WIFI network connection by double clicking it and clicking on wireless properties and then the security tab. Confirm your security key exists and is correct.
Sep 03, 2014 | Microsoft Windows Vista Home Premium with...
Acer driver for wifi connection for model acer aspire 4736z and operating system windows vista ultimate
just press FN in your left side keyboard and press F8 to see your wifi connection in your operating system windows.
thank you...
Jan 29, 2011 | Operating Systems
Proxy Settings in Vista
You have to disable your proxy settings from internet explorer.
Open internet explorer.
Click on tools >> internet options >> Connections
>> LAN settings >> uncheck everything
and then click on ok >> ok
and then close internet explorer and check your outlook is working well or not.
Mar 29, 2010 | Microsoft Operating Systems
How to make vista act as router? without using any outside router !! the inbuilt wifi syatem should act as router..
Yes well IF you use two network cards, a WiFi Adapter & an Ethernet Adapter, you can do this, now with a WiFi adapter, as you say, What you do is connect to the internet on the PC, and "Share" the internet connection via the WiFi. You set up the WiFi as either an "Access Point" or a an "Ad Hoc" network, if you want to communicate with the "Other" PC's, and have then communicate with you, as well as access the Internet. So setup is simple, using the manufacturers DVD install the WiFi. card, then, Set it up as you wish, the PC's that connect should be in the same Workgroup, have sharing enabled and be passworded too then as said connect to the Internet and the "Other" pc's will be able to "Burrow" out through you Internet, through the ADSL Modem attached to the "Main" PC. Usually via the Ethernet port. You still need to set up an SSID and use a WAP/WEP key for security. on the WiFi card.
Mar 08, 2010 | Microsoft Windows Vista Home Premium with...
Hi folks, I have Sitecom wifi in my home - works a treat with my pc. It used to work with my Toshiba laptop. Then I stayed in an hotel in France, fiddled around successfully to get wifi in the hotel, and...
Click on Start > Right Click on "Network" and choose "Properties".
Click on "Connect to a Network" about in the middle of the screen under Wireless networks are available.
Find your router's SSID in the list and Right Click on it and choose "Properties".
Change the Encryption type to whatever your router is set up as. Example: Choose WEP and type in the 64 or 128 bit key that matches to your router.
If you are unsure what security options are set up on your router, please refer to your routers documentation on how to retrieve or change that information.
Dec 11, 2009 | Microsoft Windows Vista Home Basic Edition...
My vista wifi can't connect to the internet
Make sure Internet is enabled for that connection. Try plugging directly in to the router and see if you get internet.
May 23, 2009 | Microsoft Windows Vista Ultimate Edition
go to networks and sharing centre. There youll find an option called create a network. Select network type as 'adhoc network' and give a name. on your friends pc connect to this network
Jan 09, 2009 | Microsoft Windows Vista Ultimate Edition
Traveling with Vista
re install your wireless drivers and try it ........
Dec 22, 2008 | Microsoft Windows Vista Ultimate Edition
Driverless pc camera is not supporting for vista help me to solve
The only thing you can try is installing under administrative rights the windows xp driver using compatibility mode for windows xp, this has about an 80% chance of working. I did it wiith my logitech cam that is no longer supported by logitech and is not compatible with windows vista and it worked, of course I don't have all the capabilities I had with Windows XP with the cam but it still works for chat etc.
Dec 21, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
19 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
