I can do a search and it finds the address, but no names appear in address book? and when you hit the scanner button you get the message on the screen "Destination cannot be used now" How do i get the ldap address to auto pull into the address book.
Remember that all DIGITAL machines use the scanner to read an original document,even when they make a copy! If you can get a copy from your machine, the scanner is ok! Its the Path for the scanner data that is faulty or incorrect / incomplete. Check drivers, IPs, etc. This is a communication error not a machine error.
When it say the list can not be used, it means the hard drive/disk thet keeps your addresses have failed. The fast way would be to format the hard drive/disk and re-program your info. This commonly happens when the hard drive/disk is active during a power surge/failure or incorrect shut down. Go to service mode by pressing yellow button then 107 then hold the red/stop button for more than 5 seconds, when the screen changes press the first option on the screen(should be copy or system), now press 5832 (HD format) and enter/execute, when "completed" is displayed switch off and on. Now open your internet browser on PC, take out the web address and input your printer IP and press enter, username-admin, no password, on the left of the screen click on address book, now go to add, input all you info and press ok, now log out on the top right of the screen and test scanner.
SOURCE: Ricoh 1515MF Scanning
Easier said than done...you'll probably need a tech for this one.
First..to scan to folder you require a software called "scanrouter Lite" from Ricoh, which is actually kind of hard to get a hold of these days, since it's nnot supported anymore, and then the configuration is not easy , because it is proprietary...meaning only Ricoh uses it, and it is almost impossible to configure for anyone else that has not used it.
There is however Scan to email, and for this you can open a web browser, and type it's Ip address (if you have it connected via tcp/ip port), enter "admin mode"...user name= "admin", password = "password"...then enter all network settings...IP, DNS, POP,SMTP, etc. then in "address book" enter your destination settings.
This is not a configuration that is easy for a novice either, and it is also not compatible with an email server that uses authentication for outgoing mail.
I may not have helped, b ut I hope I clarified.
SOURCE: Richo 1515 MF Error message: 12320 couldn't find the scanner.
The scanner had been previously configured and did work on another PC that crashed. We used adobe 5.0 to import. (obv this was awhile ago) I remember having this problem then but I don't remember how we fixed it.
It's a MF and the PC can print to it, but I can't get the scanner to communicate.
Any help appreciated.
SOURCE: Device does not recognize delivery server
this device does not support scan router v2 lite.
your best bet would be to set up using SMB scan to folder.
set up is pretty straight forward create a folder on the root of C: ie C:scans
share the folder with full permissions, simple file sharing has to be turned off!!
then go into the device web page using the IP address ie: 192.168.xxx.xxx.
go to configuration and smb create a user name ie: bill then point the device to the computer you created the folder on, ie: bill's pc/c:scans
save the configuration log out of the web utility reboot the device and you should have succesfully created an smb folder share.
if this resolves or answers your query please rate me accordingly
good luck and thanks
SOURCE: How to delete an email
Hi, the email addresses are stored in the copier's address book. To delete one, press the User Tools button, then go into System Settings and go to the Administrator Tools tab. Choose Address Book Management, and a list of all the users will be shown. Choose the user whose email address you want to erase and press Delete. That address will be removed from the address book.
