Question about Microsoft Xbox 360 Console
The 4th controller port flashed red i put the hard drive back in then it worked. i would like to know what just happened
  • 47 Answers
Hi there, your answer can be found at this link under section 4 hardware failure.
http://forum.teamxbox.com/showthread.php?t=472553
Posted on Jun 21, 2009
Nothing happens when put in USB slot!
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
May 22, 2011 | LaCie iamaKey 130871 Flash Drive - 16 GB...
My DameElec 2GB is not working on my XP Computer
try installing the flash drive once through add new hardware wizard from control panel. it might fix the problem for you. also plug the device directly into the usb slot present in the backside of the computer.
Jul 17, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
When I put my DaneElec 4GB USB Drive into my USB port, nothing happens. We have Vista.
Do other USB devices work when you plug them in the USB port?
If they don't then you have a faulty USB port otherwise the DaneElec is faulty or needs formatting.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 18, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
SanDisk 2gb flash drive not responding
Go to "Control Panel>>>System>>>Device Manager.Once in Device Manager,then click on "Disk Drives" (Make sure your flash drive is plugged in before you do this).You should see your flash drive listed by it's name (SanDisk Cruzer...). If you don't see your flash drive listed, the computer is not recognizing it and your drive may have been damaged by static electricity. If your flash drive is listed, then it's a more complicated troubleshooting procedeure than I can Walk you through in one posting. So try looking in "Device Manager" and then let me know what happened.
Jul 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Issue Installing 4th Drive Device (2 DVD Drives and 2 Harddrives)
You cannot plug an IDE ribbon in the floppy slot (port). The total IDE drives you can install is four (4). But check your jumper configuration. The DVD & DVD/CD-ROM cannot have the same jumper configuration to share the same IDE slot. One has to be MASTER (MS) and the other SLAVE (SL). Or you may put both drives on CABLE SELECT (CS).
Apr 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
External hard drive cannt detect
Could you let me know, what happens when you insert the External HD in the USB port............and also go to Device Manager and check if their is any Yellow exclamation mark across USB Controllers......if so, then Right click and uninstall all the USB ports and Restart the Computer.......If you see a RED mark, then just Right Click and Select Enable.....just follow the steps as given....and let me know...Take care
Jul 31, 2008 | Computers & Internet
Pictures
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Then once the computer recognizes teh drive you will be able to send any file through right clicking the mouse and going to "send to" "removable disk". Let me know what happens.
cynthia
Jan 14, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flash drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. When it opens right click on your mouse over the document you need and click send to: desktop, ect. Let me know what happens.
cynthia
Jan 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problem with sandisk 2GB Micro USB Flash Drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Jan 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
