Question about Hoover H120M Front Load Washer / Dryer
Hover H120M Door seal
Do you have to remove drum to install new seal
  • 75 Answers
Hi there to remove the door first remove the front lip with a small flat screwdriver then remove the lid and tilt the w/m 45 degrees back you can then gain access to the inner spring band wich is held on with a 8mm nut and bolt
Posted on Dec 09, 2007
How to replace door seal miele novotonic 502
Hi Adrian,
Open machine door then turn power off. Remove 3 bolts on front of machine. Remove the soap draw and remove the 2 (or 3) screws.Separate the front of the door seal from the metal front of the machine and fold the door seal in towards the drum. Front of whole machine will now hinge open (there is a spring catch at the bottom where the pump filter is - so dont be scared to use a little force). Use a screwdriver to loosen and remove the metal wire clamp that sits around the door seal. Once off, door seal can be removed from the outer drum. Replace with new door in reverse order. Note that putting on the new door seal to the outer drum is a bit of an art and may take you a few attempts (so be patient but persistant), as you must make sure it is seated in position correctly. Good luck.
Aug 19, 2015 | Miele Washing Machines
How to change door seal on miele w698
Normally they're held on with 2 wire rings, 1 at the edge of the seal at the door opening and the other on the edge of the outer drum. Unplug your machine and remove the lid, this will help access and give you more light to work with. Remove the ring at the door opening first and pull seal from the lip. Access can now be made for the one at the drum. Do the same for the one on the drum.
When putting in new one reverse the procedure and start at the drum, make sure you have the seal the right way around, normally holes in bottom of seal for drainage. Thread the seal over the lip and then put ring on. Same process for the front. Put lid on and plug machine in and test for leaks.
Dec 29, 2012 | Washing Machines
Replacing door seal on w698 miele
Dec 29, 2012 | Miele W865 Front Load Washer
Door seal
It's held in place by 2 metal rings, 1 just at the edge of the seal of the door opening and 1 at the edge of the seal to the outer drum. Unplug your machine then remove the 1 at the door opening, this will allow acces to the 1 at the drum. If you remove the machine lid it will give you a bit more light to work with and you may be able to access the ring easier to remove it.
Refitting is the reversal of removing it. Fit the drum one first and then the door side and make sure you know which way around the seal fits, usually has drain holes in the bottom section of the seal near the outer drum.
The rear drum wont come off as i would expect
Yes, Undo the 32mm nut, first. And, don't get the bearings dirty with dust from the brake drums, or , if you do, replace the inner and outer bearings with new greased up ones.prev.gif next.gif REAR DRUM BRAKES Brake Drums REMOVAL & INSTALLATION CAUTION
Brake linings contain asbestos. Asbestos is a known cancer-causing agent. When working on brakes, remember that the dust which accumulates on the brake parts and/or in the drum contains asbestos. Always wear a protective face covering, such as a painter's mask, when working on the brakes. NEVER blow the dust from the brakes or drum.
  1. Raise the vehicle and support safely.
  2. Remove the wheel and tire assembly.
  3. On vehicles without rear bearing hub, remove the dust cap, cotter pin, nut lock, wheel bearing nut and washer from the spindle. Remove the outer wheel bearing. Remove the drum with the inner wheel bearing from the spindle. If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes. Remove the grease seal.
  4. If equipped with a rear bearing hub, remove the drum by removing the retainer screws from the drum and pulling the drum from the hub assembly. If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes. To install:
  5. On vehicles equipped without rear bearing hub, lubricate and install the inner wheel bearing. Install a new grease seal. Install the drum to the spindle. Lubricate and install the outer wheel bearing, washer and nut. Adjust the bearing preload following the procedure outlined in the "Rear Wheel Bearing'' of this section. When the bearing preload is properly set, install the nut lock and a new cotter pin. Install the grease cap.
  6. On vehicles with rear bearing hub, install the brake drum to the hub assembly and install the retaining screws.
  7. Install the wheel and tire assembly. Adjust the rear brakes as required.
  8. Apply the brakes until a firm pedal is obtained, prior to moving the vehicle.
Jul 12, 2010 | 1991 Hyundai Excel 4 Door
Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
Dec 06, 2009 | Kenmore 43142 Front Load Washer
Does the drum have to be removed to replace both bearings and oil seal on an indesit wash machine type we16
No, remove the drive belt pulley and remove the 8 bolts holding the x shaped cast iron frame with the bearings in, lay the washer face down (ensuring adequate protection to the door and controls) whilst pulling the x shaped frame away from the drum tap the threaded shaft lightly with a rubber faced mallet and the frame will come away complete with bearings and seal. To replace the frame (with new bearings and seal installed) I used a large socket and long bolt to draw the shaft through the new bearings.
Aug 05, 2009 | Washing Machines
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
GE Front Loader rubber boot completely out of shape
You can replace the rubber door seal yourself if you are logically minded and are handy with tools. Isolate the washer from the mains supply. Remove the top fixing screws at the back of the washer. Slide the top of the washer to the rear of the washer and remove. Now you will be able to see the outer drum and the securing band to the drum. This needs loosening and moving clear of the outer drum so you can disconnect the seal from the drum. When you open the door, you will find see that the door seal connects to the washer outer body. You should see a holding catch probably made of plastic. This has to be removed and take care not to break anything. When re fitting the seal,you will find on the front inner edge a small hole, this must be in the 6 o'clock position. Working from the door access, feed the new seal on the outer drum and secure it with the retaining band that you removed earlier, at this stage do not fully tighten as you may need to readjust the seal later on. Now working at the door, feed on the door seal and position the small hole at 6 o'clock. If you find that the seal is twisting, then you will have to readjust the the seal on the inner outer drum. When everything is lined up, tighten the inner securing band then the outer retaining band by the door. Recheck that the small hole on the door inner lip is at 6 o'clock and both the door an outer drum securing bands are tight. This done, check for leaks by part filling the washer and then putting the washer on an emptying cycle. If all is well, then isolate the power to the washer and refit the the top of the washer and secure with the screws you removed earlier. On no account put your hands or tools inside the washer when it is on and connected to the power supply.
I have not yet replaced a door seal on your model of washer, but I have done quite a few and the process is the same. I hope you can follow these instructions and if you come across a snag, think about it and i am sure you will find the solution. You can always get to me at FixYa.
Oct 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Bosch washing machine
i am recently retired appliance engineer of 20 years, the rear door seal clamp is generally nowadays a large thin spring that is slightly hidden by the concrete weights at the front of the drum, if thats the case the door seal will just come off with a good firm pull round the drum edge, fitting as a reverse of removal, place the door seal in the groove so it fits like it should, then stretch the spring and fit that into the outer groove round the lip of the door seal at the drum end, once that is done fit the seal on the front panel lip, then replace that clamp, check all is fitted securely before running machine its one of those jobs that hard to explain how to do it, hope i have helped a bit, its easier to work through the front door opening than from above? if i have please rate me thank you
Sep 13, 2007 | Washing Machines
Hoover H120M Front Load Washer / Dryer Logo
112 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
