Question about Echo Garden
My echo will start ,but will not run.
My echo is a 2100.cc weedeater ,my echo will start, but it will not run.
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spraywith carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 25, 2009
  • Jim Parker
    Jim Parker Jun 28, 2009
    Did this solution solve the problem?
    Jim
  • Bill Moose Nov 16, 2011
    I have an issue with same model - will run & idle just wont go to full throttle with out manipulating the choke lever and holding trigger in - any ideas Jim
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
no not fly wheel maybe coil if not sparking check switch fist is on for sure or bad plug coil expessive try squrying some starting fluid in the carb check compression has to be above 90lb to start check and see if carbon has block exhaust port do all this first
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
What is the correct fuel for my Echo gt-2100 weedeater?
The manual is available here:
http://www.echo-usa.com/getattachment/0c00d42e-4da8-44dc-a38d-87fe3a46fa46
Page 3 gives the oil/ fuel ratio as 1 to 50 with oil approved by echo. That's just over 2.5 US fluid oz per US gallon or 20ml per litre.
Aug 19, 2011 | Garden
Echo es-2100 is running real dogie. Won't run @ full power. Someone told me to clean or replace exhaust filter. Where is it? What does it look like?
sounds like the exhaust is indeed stopped up echo part number 14586240630 is the exhaust screen, they can be easilly cleaned with a torch to burn off the carbon build up.......hope this helps
Nov 21, 2009 | Echo Garden
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo polesaw won't pick up gas, took carb apart still no run.
Vacuum test the fuel line and check the fuel filter.
The fuel line could be cracked.
Mar 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Open Questions:
Garden Logo
540 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
