Question about Peavey VTB1 1-Channel Amplifier
The volume knob has broken off at the base on chan 1 of my peavey KB100 keyboard amplifier. part needs replacing in NW London?
    Scholar:
  • 109 Answers
Was it the know or the pot? The pot is the metal(sometimes plastic) shaft with a nut securing it to the enclosure.
Here is your nearest registered Peavey service center. http://www.peavey-eu.com/support_2_detail.php?flag=GB&lan=UK&var=ser&key=SERVICE
This could also be repaired by someone with electronics knowledge. Just would need to know the pot taper and resistance. This would be on the front of the pot on the same side as the shaft. The enclosure would need to be taken apart.
Posted on Jun 23, 2009
Screams loudly when turned on. Knobs at o, nothing connected to it.
How long have you had the KB2?
These are hardware problems. There may be broken solder joints, connections to ground loose / broken, the power-amp circuit (LM3886) is damaged etc. Check carefully. Disconnect the electrical contacts before checking out. Reflowing all of the solder joints.25897496-xykdzr1cdriwl1tmr4ngy0qt-3-0.jpg
Oct 07, 2015 | Peavey Kb2 1x10' Keyboard Amplifier
How do I open a peavey unity 2000 SM mixer
Remove all the knobs. Remove all the nuts on jacks. Lift the black pin fasteners. Remove screws on side panels. Total disassembly is required.
Apr 28, 2014 | Peavey Audio Players & Recorders
Peavey floor monitor speakers
you can bypass the volume controller and use the master control. just take out the volume controller and splice the wires from there straight to master control.
Feb 23, 2009 | Audio Players & Recorders
Peavey TNT115 AMP cuts out
The problem is in amplifier section caused by change value resistor or leak capacitor or cold ,loose or crack solder joint parts this the common problem of over heating and shuts out the amplifier caused by abnormal distribution of current,try to check all the capacitor and resistor and replaced the defected parts ,so your receivers works normal again.
Hope it may help you;
Regards;
VOTIT
Jan 05, 2009 | Peavey Audio Players & Recorders
Need the instructions for a peavey 158 Rage amp
Here is the link to the Peavey 258 Rage. The difference is the 158 is 15w and the 258 is 25w.
http://www.peavey.com/assets/literature/manuals/00583600_4.pdf
Dec 27, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey amp
You could also use speakers rated less than 400 RMS provided you dont crank the volume knobs all the way up.
I think the CS400 is 200 Watts RMS per channel into 8 ohms
400 watts bridged
Here's the manual. You'll need acrobat to open it.
http://www.peavey.com/assets/literature/manuals/80300990.pdf
Dec 05, 2008 | Peavey CS 1400 Amplifier
Need a Peavy Unity Series 1000 Mixer manual
Hi, I have the same problem with the sliders. The board is diffucult to open. You have to take off all the knobs, plastic inserts on th XLR's and nuts on the 1/4' jacks. (Not to mention those black plastic holders.) The slides are 10k and come out quiet easily if you use solder wick. The main board is held in by about 20 of those black plastic holders. You have to release them one at a time starting at the front of the board and work right top left, row by row. The holders will stay on the bottom of the mixer. Peavey.com has the slides in stock for $3.72 each. The phone number is 1-877-732-8391 ext. 1386. (don't forget to order the knobs for each of the slides) Hope this helps. Frank.
Jan 10, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey VTB1 1-Channel Amplifier Logo
2,950 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
