Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
My D1-624 does not send a signal to my laptop
  • 50 Answers
If you can't see your network on the list of networks on your laptop,
then make sure you're not too far away from your router. Bring it over right next to your router and try again.
If you can see it, but you can't connect to it,
try resetting your router by holding the reset button on the back for 10 seconds.
Then, refer to the manual on how to reconfigure its settings (unless you already know how to do it yourself)
Hope I helped,
Tom
Posted on Jun 21, 2009
Trying to connect my laptop to the tv
Some details are needed - what type of connection from laptop? VGA 15pin or composite video for example. What kind of TV - I assume some modern flat panel. Did you use the function key on the laptop to send the video signal to the external port. Audio gets supplied to the audio port all the time so that is why you have audio, but the video signal is normally directed to the LCD screen. The function key (F5 or F7 typically) changes this and blanks the LCD and send the signal to the external ports. Press again and you get both LCD and external ports together. This is absolutely the most common problem with people hooking a laptop up to an AV system or device.
Dec 31, 2013 | Televison & Video
No signal monitor F-417
screen has been identified and installed but you need to send laptop signal to this second screen
there will be a key on the keboard or you can right click the desktop then proceed to send signal to the attached second display
Nov 26, 2013 | Neovo Computers & Internet
I am trying to hook my notevision projector to my laptop so that i can show a powerpoint. I did not receive a cord with my projector. Which cords will i need? I received a usb to usb and VGA cord but i...
I tend to use the VGA cable. Once connected, switch the laptop on until you get to the desktop, then switch on the projector. Some will see the signal, if not, simoultaneously press your FN and relevant 'F' key to send the signal out to the VGA. You may need to do this 3 times, once to send to projector, one to send back to laptop screen and then once to send the signal to both projector and laptop screen. Sometimes this can take a short amount of time. You may want to change the projector settings to the VGA input so it doesn't constantly search for a source. If you still have problems, go into properties on your laptop and advanced. you m,ay need to unclick the box saying 'Extend to..........' (You should find what I mean from this, I am in front of a pc therefore the settings are slightly different.)
If nothing then works, it may be your video card.
Good luck
Aug 11, 2011 | Sharp Notevision PG-M20X Multimedia...
Hi there, i got a usb air card for my laptop and i want to send out a signal to my belkin wireless router (with a cable) so that it can send out a wireless signal and be able to put my wireless printer on...
Sure, I can help. First off I need to know more information. Are you planning on connecting the printer, through USB, to your laptop then sharing the printer from there to other computers? If so, it is a matter of adding that printer, going into the printer properties, sharing tab, and sharing the printer. Or are you trying to share your printer wirelessly? If so you may need to buy a wireless print server. It acts as a base to share that printer and then allow you to wirelessly find it and connect. If the above doesn't help please tell me the make and model of your printer, laptop, and wireless router.
Best, -Mind
If you need further help, reach me via phone at https://www.6ya.com/expert/clayton_0b2096930c0c699a
Aug 03, 2011 | Belkin (F5D7230-4) Router (587009)
I want to send a wireless signal from my laptop to two viewsonic pro8400 projectors at the same time. I think I need a wpd-100 wireless adapter for each projector. Is that right? What do I need to send...
you cannot display an image over a wireless network to your projector. All you will be able to do is control the projector through wireless. The image signal has to come from a cable input such as hdmi or vga, composite or component. This particular projector though HAS to be hard wired to allow wireless devices to control it anyway. So you idea of sending a wireless signal to view images from your laptop will NOT work.
Apr 05, 2011 | ViewSonic USB WIRELESS ADAPTER...
Hi, my Name is Monica. I have a 3mpro110. It works perfect with my tv, but not with my laptop. I have windows 7, it seem that the computer does not detect it. Do I have to install a special controller to...
Are you "sending" the image from your laptop?
That is you have a function key, usually F7 (IBM) or F8 (Dell) to send the VGA signal. Press the Function FN key and F7 or 8 together to send the signal. (Maximum resolution of the 3M is 1280X768)
Good Luck
Aug 14, 2010 | 3M MPro110 Micro Professional Digital...
"No signal" even though connected to computer
You probably have to tell the laptop to send a video signal to an external display--(i.e. <altF4 or <altF8) The proper function key will have a TV screen symbol on it. Default mode is "laptop only" By pressing and holding the alt, then pressing the appropriate function key, the laptop will switch to the next mode, laptop/external display. The last mode is external display only. By pressing the sequence again, you'll return to "laptop only" mode.
Sep 08, 2009 | Toshiba TDP-SP1 DLP Projector
When I cconnect the laptop top to projector I get serch for signal. How do I resolve this.
Your laptop is probably not sending an output signal. Press F8 or funtion & F8 on your laptop to correct the signal issue.
good luck
Jul 28, 2009 | Dell 4100MP Multimedia Projector
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
