Question about Westinghouse 26" LCD Flat-Panel HDTV
Remove smudge lines on a HD TV - Westinghouse 26" LCD Flat-Panel HDTV
  • 3,600 Answers
I use clean Dr. from Wal mart it has no abrasive fluids and is for flat screen tv's and lap tops cost 3 bucks for a 9 oz spray bottle and with paper towels it leaves the screen streak free,
Posted on Jun 21, 2009
Scanning duplex I get a line down the righthand side of all alternate pages?
With very limited information, I suspect if you observe closely on the side that has the line printing you will find a dark smudge on the glass. If this is found you should be able to use a little rubbing alcohol on a clean cloth an remove the smudge.
Mar 28, 2016 | Fujitsu ScanSnap iX500 - document scanner
Why does my flat screen have black line and smudge on screen?
If you have a black line on the screen press menu button on emerson tv remote. If line id still there then the lcd screen is bad. If war contact auth servicer. If out of war relace the tv.
May 10, 2014 | Emerson EWL3706 37 in. LCD Television
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Feb 19, 2010 | LG 32LG30 32 in. LCD HDTV
My tv screen has several big smudges on it. I've
Use warm water and you have to rub for a while but not too hard.
The longer the smudges have been there the harder to remove.
DON"T use any other kind of cleaner.
When I bought my new Sony flatscreen, I was sold a cleaner for the screen. After reading the manual it says not to use anything other than warm water, so I return the cleaner to surprized sales people!
Jan 06, 2010 | Samsung Televison & Video
How do I get smudge marks and dust particles off the front border
use dry soft cloth use some eye glass cleaner, windex on paper towl make sure itz off first
Dec 17, 2009 | Audio Players & Recorders
Blue spot and vertical smudge in center of screen. Problem comes after tv is running. Tv is Hitachi 50V500A Projection. Thank You
The problem is your light engine is failing. The part number for this is UX22201DR and is available for purchase with the following link. It runs $334 dollars and really is a part that needs to be replaced by a technician due to the complexity in tear down to remove it. Please take a few moments to rate my answer. Thanks...
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/UX22201DR/New.aspx
Nov 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Changed cartrige, now have smudge lines on paper
please check the cartridge and see if it is the recommended one the printer..
if it is .... remove it ,clean the print mouth, re fix it and try printing...
sometimes refilled cartridges also give the same problem. please check that too.
May 26, 2009 | HP LaserJet 1020 Printer
Westinghouse 26" LCD Flat-Panel HDTV Logo
469 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
