Question about IBM ThinkPad T40 2373 Notebook
Ibm thinkpad t41 does not boot up...just black screen...fan works
Have tried following:
- removed battery and ac and pushed on button for 30 sec+
- removed the memory and dvd and tried without them
- have tried holding down the F8 button while starting up
- have held down Access IBM button
- have turned it off and on many times
- have tried powering up without the battery
IS MY LAPTOP DEAD?????
  • niley111 Jun 21, 2009
    how do you install other OS such as linux, lindows or anything else if the screen is black and I do not see anything? Thanks.
    Sergeant:
  • 145 Answers
Hehe...I used to have some problems
and then came up with the solution to install other OS such as linux, lindows or anything else
and then reinstal it with windows booting...and then it works, u can try it
Posted on Jun 21, 2009
2 Suggested Answers
bangjeha
  • 15 Answers
SOURCE: ibm thinkpad no power with ac power adapter but works with battery
If prior to this it works intermittently with the AC adapter, it means the connection from the adapter power unit to the motherboard was lost and this is a typical problem with the Thinkpad. It needs a re-soldering job and not something that one can do without a proper repair manual on how to open the laptop. Try googling your problem and find out if someone has the same experience and managed to resolder by him/herself.
Posted on Oct 19, 2008
Error 0176 ibm
Lots of issues with 0176 error. Could be caused by a dead cmos battery or the system thinks it has been tampered with. I found a couple of clues for you;
The T41 Hardware Maintenance Manual gives the following instructions in case of error 0176:
"Run BIOS setup utility, and save the current settings by pressing F10."
To get into BIOS, you need to press the F1 key when you see the splash screen. I suppost that the splash screen on a T41 will display a ThinkPad or IBM logo, and something similar to "to interrupt normal start procedure, press the blue thinkvantage button".
The idea that a new motherboard might be necessary comes from the T41 Hardware Maintenance Manual. It says that in case the first instruction, i.e. get into BIOS and save current settings, doesn't fix the problem, a new motherboard should be installed.
You could try the following:
Disconnect the AC adapter from the notebook, disconnect all other cables. Remove the battery pack. Press the power button ten times in one-second intervals. Then press the power button again, and hold it pressed down for 30 seconds. Then install the battery pack again, connect the AC adapter. Press the power button.
Re: 0176 Security - The system has been tampered with
The padlock came up after removing the BIOS-battery. It is a security-feature and cannot be bypassed.
Removing the BIOS battery does not remove the supervisor-password but locks the system, if one hat been set to protect the computer from illegal use.
So either try to get the SVP from the previous owner ore replace the board.
Mar 20, 2014 | Lenovo ThinkPad R60 Notebook
Cant power up my pc, its a black screen when i push the power button but i hear the fan
First remove the laptop battery, wait 30 seconds, and reinsert battery. Make sure the battery is fully loaded. Switch on the laptop. If you see the BIOS screen, the problem is not with your hardware, but could be a driver issue with Windows. In that case, boot to safe mode by pressing F8 during startup. If you do not see the BIOS screen, the hardware is broken and needs to be repaired.
Jan 24, 2013 | IBM ThinkPad T43 Notebook
My T41 no boot, no sounds, only the fan turns on!
The motherboard is most likely damage. First remove the battery, make sure it is unplug, and press and hold the power button for 30secs. Than put the batty back in and see if it helps. If this doesn't, try removing the hard drive and memory and see if it turns on. If not than the motherboard is dead.
Jun 29, 2011 | IBM ThinkPad T41 Notebook
IBM thinkpad T41 -> get
The IBM Thinkpad has a very strong security system.
If you are seeing a lock symbol when booting then somebody has set the supervisor password. If you can't remember it or guess it (try "password", "admin", "pass", etc) then you need to find the person that set the supervisor password.
Once the supervisor password is set the T41 is very well protected and it can't be reset by removing the laptop battery or CMOS battery.
There is a way to read the password from the protection chip but this is very complicated and requires taking the laptop apart and building your own chip reader.
The instructions for doing this are are:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Hope this helps,
Chris
Mar 08, 2011 | IBM ThinkPad T41 Notebook
My ibm t41 just freezen and is not working at all
try to turn it off, pressing the power button for 10 seconds.
that should do it.
if that doesnt work, disconnect the ac plug, then remove the battery.
wait 30 seconds and start it again.
Apr 27, 2010 | IBM ThinkPad T41 Notebook
IBM R40 laptop will not start.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 22, 2010 | IBM ThinkPad R40 2722 Notebook
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
Messed with Boot sequence.Now T41 won't boot!
With the cd reboot and press F12 for a temporary boot list, select boot from cd. At this point just choose install xp and follow the prompts.
Nov 09, 2008 | IBM ThinkPad T41 Notebook
Ibm thinkpad no power with ac power adapter but works with battery
Oct 18, 2008 | IBM ThinkPad T41 Notebook
IBM T41. black screen
It's a common problem with flex of the unit causing the video chip to coming un-soldered from the motherboard. It's possible to repair but very difficult requiring luck and specialist equipment.
http://answers.yahoo.com/question/index?qid=20070710050433AAgGOTJ
Feb 01, 2008 | IBM ThinkPad T41 Notebook
IBM ThinkPad T40 2373 Notebook Logo
2,196 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
