Question about Motorola Mobility H500 Wireless Headset
How to pair motorola h505 - Motorola Mobility H500 Wireless Headset
What is the pairing code?
Pairing code for Motorola Bluetooth is 0000. I have seen some other brands as 1111. Try these
Jan 25, 2011 | Motorola Mobility H505 BLUETOOTH HEADSET
I juat want to ask the passkey for motorola h505
i recently activated and paired my motorola bluetooth headset to my blackberry 9650. I found online a motorola page through a search which had a support section in which was an illustrated guide for pairing headset to handset, which was extremely helpful. However neither phone nor headset had a correct model number listed, so I choose similar a handset and headset to use for the illistrated support. After turning on the bluetooth, making sure it is discoverable (which should be the default setting on your bluetooth since there is no screen or buttons for you to change things besides on/off and volume), and pairing the two, the phone asks for a pass code for the headset. Now as i said in the beginning you have to choose a certain model handset and headset, so in the illustration they give you pass code for the specific headset, however my headset was not listed. I have a motorola bluetooth model number h505 and i choose model number h520. The pass code given for the h520 was 0000, which worked for my h505. I just went back to the site and there is an option for passkeys (passkey, pass code, and pairing code are all the same thing). If you have motorola, the code is either 1234, or 0000 (four zeros). This is the link directly to the motorola support site, I hope this novel I just wrote helps, good luck. https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/21216/p_country_code/US
Jan 01, 2011 | Cell Phones
My LG CF360 won't use the speaker and mic on my H505
Did you find a solution for this issue? I am experiencing the sam e thing.
Jun 24, 2010 | Motorola Mobility H500 Wireless Headset
I need a passcode for my motorola bluetooth h505 to pair with new phone
Hi,it seems you have problems pairing your bluetooth headset with your new phone in terms of the pass code,
Here is the passcode;
The default passcode for the motorola h505 is '0000'
Take care of yourself and have a nice day
Mar 11, 2010 | Motorola Mobility H500 Wireless Headset
How do i run my motorola h505. I got it from a friend and have no idea how to use it.
the following procedure is dependent to the phone in use!
1. Turn on your mobile phones bluetooth function
2. On the Moto headset, From turned of state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone and work for receiving calls!
Great Success :P
Bruce
Dec 07, 2009 | Motorola Mobility H505 BLUETOOTH HEADSET
Palm treo sees the Motorola H505 device but will not pair or even ask for passcode.
In my earlier attemts, the H505 headset was probably never in "pair" mode although I was seeing a steady blue light or if it was, it was trasmitting previous Motorola Razor profile to which it was paired to. Once I found on Motorola website that other similar Motorola headsets (without power switch) can be reset by holding the two volume buttons and call button simultaneously for 10 seconds, I did reset the headset and there after my pairing attempt was successful..i.e. it stopped and asked me the passcode before throwing security error. Thanks for your support thought!
Oct 02, 2009 | Palm Treo 755p Smartphone
Pairing a moto bt h505 to a metropcs samsung sch-r410 cell phone
Try typing in 0000 four zeros that should be the default passcode unless someone has changed it
Dec 13, 2008 | Cell Phones
Motorola Mobility H500 Wireless Headset Logo
253 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
