Question about E-Machines T6216 (827103077834) PC Desktop
The purple light is flashing in the front and tries to start and won't turn on. disconnected power cord and held button in for thirty seconds still have same issue what could it be?
  • daylargo1 Jun 21, 2009
    It spins for a second and quits can you confirm it is the power supply?
  • 6,784 Answers
This can be a faulty power supply or a damaged mother board. here's how you can confirm.
When pressing the power button, inspect the cooling fan that is located on the back of the power unit where the power cord plugs in. if the fan starts then stops immediately, this will confirm a damaged power supply.
Now, if the fan continues to operate but, the CPU doesn't start to power up and load the OS, thsi will confirm a mother board issue. replace the mother board in this case.
Posted on Jun 21, 2009
  • Michael Masters
    Michael Masters Jun 21, 2009
    ok, this will confirm that the power supply is damaged. it is unable to distribute the current through out the unit. replacing this failed power unit will fix this issue.
Purple flashing light that sounds like dripping from a tap any solutions
Posted on May 26, 2010
Acer m5-581t-6807 ultrabook won't power on
Disconnect power cord. Please disconnect battery. Hold down power button for a minute. Connect power cord only. Restart it.
Jun 24, 2013 | Computers & Internet
I have an HP Photosmart C7280. The printer will not turn on. Every time I try a blue screen comes up on the display and then all of the lights start flashing.
1. unplugged the power cord for 20 seconds (actually went a little longer)
2. Held down the # and 6 keys together and then plugged the power cord back in (still holding the keys).
3. held down # and 6 for about 10 more seconds after plugging the power cord back in and didn't get any messages but once and release them It was able to turn the power on.
The printer then printed an alignment page
hope it works, if so do rate the solution
Nov 28, 2010 | HP Photosmart C7280 Laser Printer
My HP C4280 makes a loud clicking noise before it begins to print
Try perform these steps as --->
Please perform these steps as please disconnect the power cable and press the power key for 30 seconds and at the same time connect the power cable then turn on the printer and let me know the status
And also perform this steps as 1. Disconnect and then reconnect the power cord.
2. When the lights begin to flash, press and hold On and Copies button.
When only the On light is flashing, release the buttons.
When the On light is steady, 1. Disconnect and then reconnect the power cord.
When the On light is steady, the reset is complete. the reset is complete.
If the printer works then good
Otherwise Hardware issue
Jul 30, 2010 | HP Photosmart C4280 All-in-One InkJet...
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
Laptop will not boot. The power light flashes
CLICK HERE
the codes which you see are universal for all the dell laptops. find the appropriate. this will solve your purpose and guide you how to go furthur.
Sep 26, 2009 | Dell Inspiron 1521 Laptop
Hard drive fan stop working computer stop, yes I have power but but,computer will not tyrn on PC will not power up when I woke up this morning and went to use it the green light on the front was flashing...
Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
  1. Disconnect everything from the computer, including the power cord.
  2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
  3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
  5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
  6. Remove all attached devices except for keyboard, mouse, and monitor.
  7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
  8. Check the power switch:
    1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
      • If the button sticks, it should be replaced or serviced.
      • If the power button does not stick and appears to be functioning, continue using these steps.
    2. With the power cord disconnected, remove the case or side panel.
    3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
    5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
Oct 24, 2008 | Compaq Presario 5000 PC Desktop
My computer is A 135-4527... I just shut down my computer. When i tried to turn it on again here is what happend. Flashing lights ussually goes blue but now it always blue and when i hold for a few...
Could be a glitch only. Try doing a power cycle: disconnect everything like the AC, battery or USB mouse, if applicable. Hold the power button for 10 seconds. Try to use only the AC, then the battery only, then both of them.
Oct 11, 2007 | Toshiba Satellite A135-S2276 Notebook
E-Machines T6216 (827103077834) PC Desktop Logo
577 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
