Question about Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v
I have a 2 horse flowtec sprinker pump,
I don't know how to hold the pump from turning, so as to unscrew the impeller from the pump. Please help, I feel stupid. Thanks Dave
  • 990 Answers
Don't feel stupid this is a design thing to make sure I can make money and you can stand there and say "Hey I could do that" If your impeller has a lock screw in the center of it that is left hand, so it unscrews clockwise. If it dosen't have one we move on, Looking at the front of the pump take a strong flat blade screwdriver in your left hand and insert in the left side of the impeller on edge. Then while holding it firmly with a small hammer or like device give the screwdriver a sharp hit straight down on the edge to break the impeller free. If this dosen't do the job after one or two hits you will have to go to plan B. Fornthis you will need to go to the back of the motor. If there is a small round cover about half dollar size dead center pry this off and use a adjustable wrench to hold the shaft and another wrench to hold the adjustable while use water pump pliers or the like to break impeller free by turning counter clockwise. If the moter has a full cover over the back remove this after shuting the power off at the breaker then take a 3/8 open end wrench and weave it into the end of the shaft and behind the cintrifacl switch on the end of the shaft the shaft will have two flat sides you can put the wrench on again useing chanel locks or the like turn impeller off makeing sure the wrench on the back is secure. You will need to use some force to break the impeller free and if the wrench slips their is a real threat of breaking parts on the back of the motor. Now rember when you go to put it back together just hand tight putting it back on. Good luck.
Posted on Aug 24, 2009
  • Kieran Ruppert Aug 24, 2009
I just rebuilt my flowtec fpof 360ac pump with a new impeller, seals, etc. because it wasn't pumping water. The rebuild didn't fix the problem. There is still almost no pressure in or out when I tur
If you have replaced the impeller and seals there must be an air leak or blocked hose somewhere - perhaps on the inlet seal?
http://www.flotecpump.com/resources/images/517.pdf
Nov 08, 2014 | Pool & Spa
Need to remove the impeller
Turn off the system at the breaker,
Undo bolts for housing and separate the motor from the pump to access the impeller. Some styles of motors have a screw that is reverse threaded holding the impeller in place, if it has one , remove the screw. Once you have access to the impeller you can use a big pair of channel locks to turn the impeller. Take off the back cover of the motor or remove the plastic or metal cap that is covering the shaft. Use a wrench to hold the back end of the shaft as you unscrew the impeller.
Aug 29, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
I am having difficulty removing the impeller on my BaquaPure 2.0 Horse Power pool pump
reverse screw and regular thread on impeller hold back of motor with 9/16 wrench
Jul 06, 2012 | Polaris Pb460 Polaris Booster Pump...
How is the pump seperated from the motor. I am replacing the motor only.
From this question I assume you already have a motor. Anyway, most motors separate from the pumps by first taking apart the pump and removing the impeller. Some impellers have a screw in the middle that have left handed threads. Once this screw is removed the impeller can be unscrewed by holding the motor shaft with a wrench and turning the impeller counter clockwise. To gain access to the motor shaft to hold it there usually is a cover at the end of the motor that comes off. When the impeller is off there are usually bolts that hold the pump to the motor. When reassembling the motor it is important to replace the ceramic seal and gaskets. I hope this helps.
Aug 06, 2011 | Pool & Spa
How do i remove the impeller from the pump?
To remove the impeller, first remove the housing cover. There are about six botls holding this on. You then need to remove the motor housing cover from the other end. There are three small screws holding this on.
With the motor cover off you can see the other end of the shaft. You mayhave to remove or at least loosen some things on the end of the shaft to get a wrench on it. The shaft is flattened on two sides and it should take a 7/16" (I think that is the right size)wrench. Use that to hold the shaft and then unscrew the impeller by hand.
It should unscrew the conventional way (anti-clockwise). COUNTER-CLOCKWISE
I am guessing you want to replace the seal. Don't make the same mistake I just did. I got the two pieces reversed and it nearly melted my impeller shaft. Talk about a pain. Now I need a new seal and a new impleller.
Its dead easy if you get it right. Good luck.
The black grafite and the white ceramic parts of the seal touch
Thanks
May 21, 2011 | Hayward Super Pump 1 1/2 - Hp for In...
Flotec 1/12 sprinker pump runs 5 sec. and trips breaker
The pump is seized up... you can try to open it and get it spinning... make sure that there is nothing stuck in the impeller...
other then that the motor bearing are locked up and that will also cause the pump not to turn...
heatman101
May 15, 2011 | Flotec 1 - 1/2 Sprinkler Pump Composite...
How do you take off the motor from the pump assembly
Turn the circuit breaker off to the pump. Undo the band that holds the motor and flex plate to the pump. Unscrew the 5 screws on the diffuser ( front of pump ) That will expose the impeller. Remove the rear cover of the motor, (2 -1/4" screw heads) Pull off the rear cover. The impeller might have a screw in the center of it. If it does, the screw is left handed thread. Turn the screw clockwise to remove. Use a 7/16" open end wrench to hold the shaft at the rear of the motor. Put the wrench behind the plate with the two springs on the shaft. You might have to turn the shaft a little to get the wrench on. Remove to screw and remove the impeller, (counter clockwise). Unscrew the 4 motor flange bolts and pull the flex plate from the motor.
Apr 10, 2011 | AO Smith SQ1202 Pool Pump Motor
We need to know how to remove the impeller on a red jacket water pump. It is a 1/2 horse
The impeller will be threaded onto the shaft, there should be a slot or a place on the back end of the shaft of the motor where you can keep it from turning. Impeller will thread off counterclockwise
May 08, 2010 | Plumbing
Tryiing to replace motor cannot get diffuser and seal plate free how do they come apart
First remove bolts holding motor to wet end. Pull motor back and out of wet end. Diffuser should just fall off. Not held by anything, there are just some locating tabs. Next, unscrew impeller. Some impellers may have a screw holding it on to center shaft. If so, unscrew.(Backwards thread). Remove back cover on motor and hold centershaft with large screwdriver or wrench on flat of shaft. Unscrew impeller. Next, unscrew 4 bolts holding motor to seal plate.
Apr 17, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v Logo
299 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
