Question about Apple MacBook Pro with 17" Display
Screen dims and lightens - 2009 MacBook Pro 17"
It is really subtle but it is almost as if the screen is taking a deep breath. It dims slightly, pauses, then re-brightens. I've sent it in to apple for repair - ofcourse they could not reproduce my problem. Has anyone else experienced this?
Here is my specs:
Model Name: MacBook Pro
Model Identifier: MacBookPro5,2
Processor Name: Intel Core 2 Duo
Processor Speed: 2.66 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 6 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP52.008E.B05
SMC Version (system): 1.42f4
Serial Number (system): W89141RN2QT
Sudden Motion Sensor:
State: Enabled
  • 61 Answers
I've experienced it, but after a while the problem dissappeared again.....
Posted on Aug 05, 2009
I have alenovo t420 laptop that brightens and dims every second or so . tried diablind the automactic brighten button under intel but this didn't work . am at a lost and need help .
Is it problem accours in another monitor that pluged to your notebook? If no, the possibility is inverter failure. Try to replace the inverter to your service centre
Sep 05, 2014 | Lenovo ThinkPad T420 Notebook
How do you brighten screen
screen and wallpaper setting turn of auto light and screen will be bright again and not dim.
Apr 27, 2014 | Apple iPhone 4S
Dell vostro screen dims and goes off
Yes it is possible for the inverter to be bad. I would watch on eBay for an inverter that has been tested as good or is brand new. They are usually under $10.00 and may be all that is needed. You can also remove the bezel and make sure that the connector from the computer to the inverter is in there solidly and didn't jostle loose. That is also an easy fix. If either of those do not fix it, let me know and I can help further.
Dec 18, 2011 | Apple iMac Computers & Internet
My screen is dim, i can just make out the screen and what i am writing. I have tried the power saving options, brightening the screen and nothing helps, anyone know what it could be?
have you tried holding Fn and pressing the button with thr brightening symbol. on mine its Fn and F5 for brighten and Fn and F4 for dim.. buttons may vary but this should work if not you may have a fault with the sreen sensor that shuts the screen down when you close the notebook
Jan 11, 2011 | IBM ThinkPad T23 2647 Notebook
Ipod touch 2g very dim
Follow these instructions to brighten the screen.
1...Turn on I Pod
2...Slide to unlock
3...Touch "Settings"
4. ..Touch "Brightness"
5...Move the "Slider Bar button" to the Right to Brighten the Screen, Left to lower the Brightness, once you have the desired brightness on the screen you will then touch the "Settings" tag at the left corner of the Ipod to take you back to the "Settings" screen.
6.Push the button on the screen at the bottom of the player to return to the Main Screen and you are finished.
Please rate me for this Free Answer.
Dec 19, 2010 | Apple iPod touch
My panel lights are too dim and won't brighten. I checked all the fuses and they are all working fine. I turned the dimmer knob all the way to the right and they still won't brighten. When I first turn...
Your alternator may be going bad. Once the car is running, your battery has done its job and the alternator takes over. The alternator is responsible for firing the plugs, running your lights, your radio, your heater/AC, and anything else electrical, as well as keeping your battery charged. If the alternator is on its way out (or even has a less than good ground), you may experience some lights dimming, or even choppy radio signal. If the alternator is already gone, and your car is running off of the battery full time, you will also get the dimming you describe, and sooner or later the car will not even start. Take your car to an auto parts store (Advance, or Auto Zone, etc) and ask them to test your alternator. This is a free service.
Nov 23, 2010 | 2005 Chevrolet Impala
I have a apple i phone 3g s the screen is very dim
If the screen light is really dim, its possible the lcd backlight has gone bad. Does it ever flashbright?
If you need, here is a link for Iphone 3G Screen repair
Jan 17, 2010 | Apple iPhone 3G
How do you make the lighting on the screen brighter without the charger in ?
The screen will automatically dim slightly when it is on battery power, this is to conserve battery power. For maximum brightness connect the power adapter into the laptop.
On the Thinkpad laptops you can adjust the brightness by pressing and holding down the blue Fn key plus the Home key to brighten or the End key to dim the screen.
Nov 26, 2009 | Lenovo ThinkPad T61 Notebook
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Apple MacBook Pro with 17" Display Logo
530 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
