Intel Corporation S1200V3RPS Server Motherboard - C222 Chipset - Socket H3 LGA-1150 Micro ATX - 1 x Processor Support - 32 GB DDR3 SDRAM Maximum RAM - Serial ATA RAID Supported Controller - On-board Video Chipset - 1 x PCIe x16 Slot Logo
A
ANAND WANKHEDE Posted on May 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CAN NOT INSTALL WINDOWS 2003 ON SERVER BOARD S1200V3RP
BLUE SCREEN ERROR WHILE LOADING WINDOWS
Lars Olsson
Level 3:
Brigadier General:
  • Intel Corpor... Master 3,400 Answers
  • Posted on May 01, 2014
Lars Olsson
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048502
Points
10330
2answers
I just got a new PowerEdge T300 server with an embedded SATA Controller. I am attempting to install Windows 2003 on the server, but am getting a blue screen with an error IRQ_NOT_LESS_OR_EQUAL...
The server should have came with an OpenManage CD.
You boot to the CD and it walks you through setting up arrays and installing the OS.
If you don't have the CD you can download it.
Go to support.dell.com Drivers and Downloads and enter your server's Service Tag.
Dell servers have lifetime phone support so give them a call if you need more assistance. (800) 945-3355
If this helps please vote for my solution.
I just got a new poweredge T300 server with an embedded sata Controller. I am attempting to install Windows 2003 on the server but am getting a blue screen with an error irq_not_less_or_equal (0x0000000A...
Guest
This stop code, "0x0000000A irql_not_less_or_equal" normally refers to a driver problem. So this is one of the few times where the files that the BSOD lists actually is important. Next I would try to boot the computer into safemode and reinstall/drivers related to that file to see if this make a difference.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
4answers
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
1helpful
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Blue screen when loading windows 2003 server
if you get the blue screen code and type it in www.dogpile.com you can find some answers there, i would sugest that you reset all the bios settings to factory default, that normaly fixes the bluescreen on instalations, you may need the motherboard drivers for the sata and put them on floppy for the system to install the hard drive drivers.
one problem i do come accross is that sata drives are funny so in most bios settings there is a sata setting that switches back to IDE it was for backward compatability problems.
good luck
1helpful
3answers
Graphic driver problem
The Intel 852/855, 865G, and 945G video chipsets are integrated with numerous desktop, laptop, and server motherboards. Older versions of the drivers for these chipsets, often installed at the OEM factory, may conflict with patches or other drivers on each of Windows XP Home, XP Pro, and 2003 Server. Blue-screen-of-death and memory dump errors will result from running old versions of this driver. The text of these messages includes:
  • “DRIVER_IRQL_NOT_LESS_OR_EQUAL”
  • Driver conflict error: “ialmnt5.sys
  • DLL communication error: “ialmdev5.dll”
The error often occurs following Windows Service Pack upgrades, Windows Update installs, and the running of new video games. After the error appears it is usually possible to boot into safe-mode (restart and press F8 at the BIOS screen to start in safe-mode) to install the newest version of the driver. Download and install newest driver version from: http://support.intel.com/support/graphics/
I think your best bet will be to update every driver on your system and to try disabling advanced video features.
Or purchase a separate video card to install in your Windows 2003 server’s PCI or AGP slot and which already has drivers built for Windows 2003. Install that video card in the system and then disable the video Intel video chipset that is on your motherboard. (You can find closeout and refurbished video cards that might work well on sites like eBay or geeks.comno-web-bugs.gif)
4answers
Win 2003 Server Reboot
Is it loading up to windows logo? if you are not getting blue screen error massage most of the time you can fix it on safe mode. try to get into safe mode and read all logs there you will see the problem.
Top Intel Corporation Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Intel Corporation Computer and Internet Expert? Answer questions, earn points and help others
