Question about Harman Kardon HK206 Computer Speakers
HK206 speakers - bought a 2nd hand set - power plug doesn't fit
I bought a second hand pair of HK 206 speakers which came with a power plug but it doesn't actually fit into the socket in the back. Anyone know where I can get one that does fit/work?
Have tried with a universal one for a iDock which fitted, but speakers didn't actually turn on or work at all.
What are the specs and where will I be able to buy a cheapish one? Or am I better off giving up (since I only paid £3 for the speakers in the first place...)??
Thanks so much x
  • 484 Answers
Try Radio Shack. They have adapters for just about every style of audio jack.
Posted on Jun 21, 2009
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Hi. I have a pair of Harmon Kardon Computer speakers without a power adapter. The left speaker plugs into the right and the right has a place for an adapter. The only numbers on these speakers are...
According to this similar request http://www.fixya.com/support/t1489202-need_replacement_power_cord_harmon you're looking for a 12v 2500ma power supply. Take the speaker with you to someplace like Radio Shack and I'm sure they can set you up.
Or look on eBay. This one looks like it would fit just about anything in the U.S.
http://cgi.ebay.com/VM-1225-SWITCHING-AC-DC-POWER-SUPPLY-12V-2500mA-/280647116061?pt=LH_DefaultDomain_0&hash=item4157df251d
TV's are known for their audio chops. Neither are PC speakers. You'll need to access the audio through a variable output on the TV if you want control of the volume. SEE THE TV MANUAL. Or get the audio from the Cable Box directly (or any video source)
Jul 02, 2011 | Audio Players & Recorders
Will Harman Kardon HK 206 speakers work with Dell Inspiration 560 with Windows 7 and if so how do you hook them up and install
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
Jun 27, 2011 | Harman Kardon HK206 Computer Speakers
I have a harman/kardon class 2 transformer model# 661520oo3ct. It was with my computer equipment but not hooked up. I don't remember what it was for. what uses does it have?
hi,
it comes with ur desktop speaker harman kardon hk 206. it is a 12v 1A dc power supply. u can use it in any equipment which needs that power rating. only thing to remember is, check the polarity of both before connecting.
ok
Dec 17, 2010 | Harman Kardon HK206 Computer Speakers
HK 206 What size transformer does it take? 9v, 12v??
Original wall transformer is 12Vdc 1000mA current
Imput voltage depend of your country
Feb 01, 2010 | Harman Kardon HK206 Computer Speakers
I have a Dell Dimension 4500 that came with HK-206 speakers. I disconnected the speakers awhile ago. Now when I plug them back in, there is no sound. Followed instructions that came with the manual. They...
Make sure they are plugged into the green outlet on the back of your system. Check the twist lock on the back of the speaker and subwoofer and make sure it is fully connected.
Check the volume knobs on both speakers and subwoofer. Plug a headphone into the front speaker jack and check for sounds...
Go to Control Panel>sounds and make sure the speakers are enabled, restore the default audio playback settings, and check the volume controls. You can also use the hardware tab to check the audio devices & troubleshoot any that aren't working.
(Take a look at the device manager and make sure your sound is enabled...there is a troubleshooter there if your right click the device and choose properties.)
See this MS article.
Google 'troubleshoot xp sound problem"
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 13, 2009 | Harman Kardon HK206 Computer Speakers
Harman Kardon HK206 Speakers
driver-updates.net
It sounds like free but check it out first
aslo check out dell
Feb 04, 2009 | Harman Kardon HK206 Computer Speakers
HK206 speaker power supply
this is power adapter specs for HK206 found elsewhere
Made by: HON-KWANG
Plug in class 2 transformer
Model No: D12-10-1000
P/N: 66-000-118-01
INPUT: 120V 60Hz 25W
OUTPUT: 12VDC 1000mA
The polarity is negative (-) on the outside and positive (+) on the inside.
I will try RadioShack for this...
Aug 24, 2008 | Harman Kardon HK206 Computer Speakers
Lost power adapter-help!
its 12V 1000Ma (1.0A) I work in radioshack... IN fact Im dealing with this problem as I speak... I need the Polarity for this however, otherwise theres a 50 50 chance this might get blown.
Dec 12, 2007 | Harman Kardon HK206 Computer Speakers
HK206 SPEAKERS WITH USB PLUG
have you plugged anything else in to make sure the usb port is working? does the computer recognize the usb speakers when you plug the usb plug into the computer? do the speakers work on another computer? if you wiggle the usb wires around does it make a sound through the speakers? eliminate these questions so that we can move on to isolating the issue.
Oct 13, 2007 | Harman Kardon HK206 Computer Speakers
Harman Kardon HK206 Computer Speakers Logo
230 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
