Question about John Deere Muffler 1010 Diesel Tractors
John Deere 310 A reverser problem
I have an older 310A
which runs very well. I have an occaisional problem with the reverser. It sometimes won't go into reverse and this problem will continue for a time until I think its done for and then it starts working again just fine. Its currently on the fritz. Forward works well all the time. The Shift lever moves to the reverse position but nothing engages. When selecting forward you can feel the lever engage but reverse feels different. Like its not engaging anything. I don't think the problem is internal because it comes and goes. I suspect a linikage problem. Any advice is appreciated.
  • 81 Answers
SOURCE: The rear end on my 1987 750 4wd john deere quit
Check first to see if the drive belt has jumped off a pulley or the belt is stretched or broken. Next if there is a grinding noise it means the transmission has a broken or chewed up gear.
Posted on Jun 24, 2009
mhamlin63
  • 138 Answers
SOURCE: forward/reverse lever not holding in position on
Some come with a tension bushing underneath on linkage. Check that first
Posted on Jun 29, 2009
tbirdfan1
  • 3051 Answers
SOURCE: John Deere ride on mower L100 17 hp.
Hello there:
I would first check to see if there is any binding in the deck belt's or gears and make sure that the deck is not set to low that you are cutting dirt instead of grass also make sure that all of the rods and opins are secure and are not bent ok?
best regards mike
Posted on Aug 22, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
What causes the dipper stick to move so slow on my John Deere 310A Backhoe?
just a guess but could it be blowback around worn piston rings
Nov 13, 2017 | John Deere Garden
My john dere has no comoression
remove the valve cover and make sure the valves are closing if they are remove the head inspect the gasket and valves and make sure that the piston is going up and down when turning it
Sep 23, 2012 | John Deere Seat 310a 310b 401 401b 401c...
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
John Deere 310 A Hydralic problems
Jd 310 A, boom down to dig then back off stick alittle and circut loses power.
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Radiator water in oil of my John Deere 310A backhoe. What steps do I take to repair.
You have either a blown head gasket, cracked block or craacked head. Major work ahead. Hopefully, the water didn't mess up your main bearings.
Sep 01, 2009 | John Deere Kids Tractor Loader & Backhoe...
John Deere Muffler 1010 Diesel Tractors  Logo
1,022 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
