Question about Fisher and Paykel GWL11 Top Load Washer
My GWL 15 pumps so hard water comes out of the
My Fisher and Peykel GWL 15 pumps so hard on the first rinse that water comes out of the standpipe and floods the floor. I've called several people and nobody has heard of this problem. I've had the drains cleaned so it's not that. What's wrong?
  • Fisher and P... Master
  • 3,463 Answers
A washer cannot pump the water out too fast, regardless of what you have done or have been told, the problem is too do do with the drain outlet, I suggest you completely take apart the stand pipe and any other pipes connected, and thouroughly clean them .
Please rate my solution.
Thanks.
Posted on Jun 21, 2009
Fisher & Paykel GWL-11 Machine very flaky.
may I be frank there seems to be to much going off at any one time that its hard to pinpoint a solution except a new washer eric
Jan 16, 2018 | Washing Machines
How to clean water pump and diverter valve on Fisher Peykel
both have to be removed, pump has two wire connections and then turn pump anticlockwise after pulling back te locking clip, diverter valve has two or three hoses a screwed on clip and a wire connector, remove and look down each hose connecter for anything that may jam it
check the pump windings are all one even colour if not pump needsrepacing
Jul 14, 2014 | Fisher and Paykel IWL12 Top Load Washer
My machine seems to be letting the water out when its filling and then tries to wash with no water in it?
10.5 Siphoning
Typically this occurs when the Standpipe height is too low. The minimum is 33.46in / 850mm from
the floor. This is 3.54 in / 90mm ABOVE the drain hose outlet on the machine. With a very low
standpipe and a very high water level, this could result in water pouring down the standpipe prior to
the machine completing fill and resulting in no water in the basket during agitate.
If the drain hose is pushed too far into the standpipe or drain, the machine will siphon during rinse,
which could result in a 'No Taps' user warning.
Siphoning can result from a restricted drain hose or partial pump block.
Dec 21, 2012 | Fisher and Paykel Washing Machines
Model gwl 15 us not draining
find black rubber drain hose under machine and squeeze several times to loosen soap and hair gunk.
start the mahine on the rinse cycle. This should start the draining process.
Dec 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine will not turn on.
Hi just read your posting.Have you checked the power point for power with a toaster or hair dryer?If there is power to the machine then there are 2 reasons why it is not powering up.1st-- the drain pump is open circuit 2nd the control module is faulty.1st empty the machine by hand so you can look underneath the machine by tipping it back far enough to see the pump.Now the pump will either have a red or black fan on it ,or you will see no fan and that means you have the new style pump.please reply with the type of pump you have and if you have or can borrow an electrical test meter and i can guide you step by step to find out if the pump is faulty or the controller or both.
Jun 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
POWER UNIT IS NOT WORKING
sounds like the motor controller is faulty.if u have power to unit and the lights aren't on then it is either faulty controller, or faulty pump or best case broken power wire.please turn power off b4 u work on it. dont want any accidents. please reply 4 more help.
Apr 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
My machine will fill & go thru a wash cycle but wont rinse or spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Feb 08, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel smartdrive MW095AU wont spin
press start cold water starts then stops and starts about 3 times followed by error which stops machine to protect it ?
Dec 28, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
