Question about Marantz SR-7200 Receiver
Marantz SR5001 Rapidly Blinking Standby Light
Manual says take it to the repair centre - very helpful as there is no such repair centre in Delhi, India and the warranty period is over. Tried all the resets it won't listen to me and it (now rather convincingly) wants me to listen to the manual.
    New Friend:
Hello I had the issue just check 0.33Ohms it gone up to 1.5Kresistor 2 resistors on small board nest to power amp board. Issue sorted
Posted on Sep 13, 2014
    New Friend:
If u want to sove your problem then contact me on my number 9555503717
Posted on Feb 02, 2013
5 Suggested Answers
hawkwatcher
  • 67 Answers
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
This unit went into protect either due to overcurrent or dc detect. There is no way to disable protection that Marantz or Authorized servicers are allowed to give out. The early versions of this model all you had to do was unplug for a few minutes then plug back in and unit if it did not have blown amp unit would powerup and work fine. But if amp had failure it may cause more parts to fail so they changed software to not allow users ability to disable protection. Send to Marantz Authorized servicer for them to check for amp failure or mayby they just have to disable Protect Mode.
Posted on Feb 16, 2008
  • 133 Answers
SOURCE: marantz sr5001 has pcm light flashing
I suppose pcm light means that the pcm mode is turned on (pcm meaning pulse code modulation), in other words, the unit was switched to digital signal, so if the digital rca or optical TV input on your reciever is not connected to anything, then you're not getting any signal into the reciever in digital mode. You probably just need to switch the unit back to analog mode (see if there is a button that says something like digital/analog, pcm/analog, optical/coax or similar, try pressing it, see if there is any change).
I might just be totally wrong on this, however, probably the best way to learn what happened is to read the user manual if you do have it (see what the pcm light signals for and check any chapters inside the manual related to that topic).
good luck
3rq8 (Triarcuate)
Posted on Jul 25, 2009
SOURCE: Standby light is flashing rapidly and I can't turn
RECEIVER MARANTZ SR7002, FLASHING THE STANDBY about 8 times per second and will not start, HELP
Posted on Sep 24, 2009
I have a SR7001 with that problem. I found 2 shorted amp NPN & PNP transistors. Part #'s SAP17NY & SAP17PY.
Posted on Feb 08, 2011
The red light on my Marantz SR5008 keeps flashing and wont turn on. How can I fix this
Disconnect everything and then plug in only the power. If the light still blinks, the PS is probably damaged and will need to be serviced. If the light doesn't blink, you have a shorted connection. Speaker wires are probably the most likely.
Oct 07, 2014 | Marantz SR5001
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination.
Manual: http://us.marantz.com/DocumentMaster/US/SR6004-5004_U_EN.pdf
Sep 27, 2014 | Marantz SR5004
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
Stereo goes into standby when powdered up. I then have to unplug it and the same thing happens again
Check the speaker connections. There may be a short.
If not most likely there is a blown output stage causing the receiver to go into standby
Nov 29, 2009 | Marantz SR5001
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
I have a marantz sr5001 and it displays check dsp rom and some times it wont power back up after standby. can any one tell me what it is
On the Marantz SR5001 if you get the "CHECK DSP ROM" it can be fixed by holding down the Multi and ATT buttons at the same time for 3 seconds. This will default any setting so be sure to know the correct input setting for your setup.
Apr 15, 2009 | Marantz SR5001
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Feb 16, 2008 | Denon DRA-395 Receiver
Marantz SR-7200 Receiver Logo
491 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
