Question about Maytag Neptune MDE6700A Electric Dryer
Just moved and put 3 prong plug back on dryer I had changed to 4 prong with last move. shape of plug in wall is different, "L" shaped on bottom. Do I need a different plug cord? tried to plug this one in but it feels like i'd have to force it in.
  • 331 Answers
Careful my friend....go here... the voltages maybe different . look at the NEMA chart and compare also some of the NEMA plugs look alike
http://www.nooutage.com/nema_configurations.htm
please respond
Posted on Jun 21, 2009
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
The dryer cord does not match my plug. is that cord required or can I buy another dryer cord and use that instead?
cord for dryer should be 3 prong and center being L shape or a 4 prong dryer corder with an L shape either one is fine aslong as its a dryer cord ,,,, donot put range cords on dryers they use different amperages and could trip your breaker and cause electrical overheating of wiring....
Jan 28, 2011 | Kenmore Elite HE4 Electric Dryer
We just moved and this house has a 4 prong dryer plug and our last house had a 3 prong dryer plug. We bought a new plug and hooked it up as it says and still nothing. Any help would be much appreciated!
You may have inadvertently incorrectly wired the dryer power cord. The following link epxlains the differences between the 3-wire and 4-wire configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Make sure you have the wires connected properly at the terminal block. Pay particular attention to the difference in how the ground and neutral wires are connected. If you have any questions, please post back and let me know. I hope this helps you.
Dec 01, 2010 | Roper REX4634KQ Electric Dryer
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
I don't have the same plug as the one on my kenmore 70 dryer
Hi, You can either change the outlet or change the cord. Easiest would be to get a new caord. Make sure you get the right one. There are two different ground posts.
One is straight and one is L shaped.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Estates dryer by whirlpool has a 3 prong plug. the wall has a 3 prong w/an L shape. where can I get a wall switch to match the 3 prong without the L shape as this is a straight shape
Home Depot, Lowes, etc will sell these type plugs in the electrical section. If installing yourself, be sure you get the wires in correct positions, let me know if you need info on that.
Nov 16, 2008 | Whirlpool Dryers
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Maytag Neptune MDE6700A Electric Dryer Logo
283 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
