Question about Instant Cameras
Canon ixus 2 aps camera
Haven`t used it for years. opened film compartment by mistake, enough power in battery to partially rewind film, then stopped. put in new battery (CR2), display flashing ok but no response from buttons and can`t open film compartment. what to do eh?
  • 363 Answers
SOURCE: Camera Flash Pentax MZ7
If there is enough ambient light then the flash doesn't need to be at full power. The noise could be the lens focussing.
Posted on Sep 22, 2007
  • 619 Answers
SOURCE: Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Posted on Feb 19, 2008
SOURCE: Film advance inoperative
check the polarities of the battery.
Posted on Apr 02, 2008
  • 691 Answers
SOURCE: My film rewinder/opener is missing
I have found using a pair of pliers has worked
poke in where the opener goes and try to catch the edge of the opener lever and pull up
Posted on Nov 10, 2009
  • 238 Answers
SOURCE: Anyone know where I can access a user manual for a
This is Canan Elph2/ İxus II User Manual.
If this helpful please vote with higher rank. Thank you.
Posted on Feb 25, 2010
  • 31 Answers
SOURCE: User Manual for a Canon Ixus 3 Aps Camera
Posted on Aug 16, 2010
0 characters
1 Points
How to open film compartment
The camera must have good batteries for the compartment to open.
Jun 20, 2014 | Minolta Vectis 40 APS Point and Shoot...
How do I rewind the film in a canon sure shot supreme?
I have a cannon sure shot and it is digital and has no film. Open the battery compartment and pull out the sim card.
Feb 17, 2012 | Canon Instant Cameras
Where and how do you insert film on a minolta vectis 2000 camera
Essentially, you probably don't as APS film is no longer made and is getting difficult to get processed if you do get some old stock.
But like on all APS cameras, there's a lock on one end of the camera and usually you turn it to open a small door on the bottom of the camera. The APS film cassette gets pushed into the compartment and when you close the door and the camera *should* wind the film ready for shooting and lock the door so that you cannot open it until the film is rewound. The cameras are entirely battery dependent and many used CR2 lithium batteries which are disproportionately expensive and hard to find except from online suppliers.
Unfortunately APS was a badly engineered system from the start, so the cameras didn't tend to last long before suffering major faults. You may wish to bear that fact in mind as those faults won't show until you load a film and any film you do find will likely cost more than you can buy another APS camera for. They're widely available for free or for about a £ or two from almost any charity shop (not from the one I work in though as I always put them straight into the recycling bin as they're a liability).
Aug 14, 2011 | Minolta Vectis 2000 APS APS Point and...
Canon EOS 300x battery problem: it doesn't work, even with fresh batteries. The LCD battery indicator blinks as they we're dead.
First make sure the batteries are in the correct position/orientation clean both battery terminal and look down inside the battery compartment make sure the "lower" connection is clean (shinny) if not you may need to use a pencil eraser with a piece of sandpaper affixed to it to get down in there and scrub off the corrosion. Another thing and I've run into this myself on a Canon Elan IIe was the battery indicator showed new batteries as dead but the camera attempted too function so, I just used it and used it and withing a few minutes the battery indicator showed the battery state of charge more accurately.
Mar 04, 2011 | Canon Instant Cameras
Minlota Vectis 2000- I want to open the film door without battery power. Is there an emergency release?
In short, no. The camera must be dismantled. If the film hasn't rewound, then if you wish to save your images you must dismantle it in total darkness: not easy! As the camera is usually a write-off anyway I just slowly crush APS cameras in a vice in my darkroom until they pop open enough for me to extract the film.
If the camera is faulty and not just in need of a fresh battery, then after recovering your film just chuck the camera away; it's not repairable and it definitely isn't collectable. APS was a poorly-engineered system from the start and 35mm has outlasted it largely because APS cameras were generally highly fault-prone and unreliable. It also didn't help that the image quality was worse than on 35mm because of the smaller negatives.
It's not all bad news: 35mm cameras of most types are now mostly near worthless and so commonly available for free on FreeCycle and Freegle as are APS cameras if you really want another.
Hopefully you will just need a fresh battery, but either way I hope that you manage to recover your film successfully.
Aug 08, 2010 | Minolta Vectis 2000 APS APS Point and...
E is flashing all the time when on?? can not open camera to remove film. Camera is locked--battery is new.
The flashing E means that the film has no more exposures left. When this occurs the film is usually automatically rewound into the cassette and the loading door can then be opened.
In your case, the film has not fully rewound and so the door remains locked. A fresh battery usually cures it but has not done so in your case. You can try using a pointed object such as a pen or pencil to press the manual rewind button on top of the camera (below the "select" and "enter" buttons on the top plate) but if that fails then you will need to break open the camera in total darkness to remove and rewind the film.
Breaking the camera seems drastic, but if the camera is broken then it's effectively irreparable anyway. APS cameras were a very badly engineered system and there are very few which are still working these days as the film transport mechanism was simply awful. There were various other problems with them as well, so many don't work for other reasons.
After you recover your film you can either replace the camera with another one (APS film is an almost dead format though) or switch to a conventional 35mm film camera which has better image quality as well due to the larger negatives. Either way, there is absolutely no need to actually pay for one; there are millions of them sitting unused in people's drawers and cupboards and you can either wait for one to be offered on your local FreeCycle/Freegle groups or request one. Note that a rule of these groups is that your first posting MUST be to make an offer, but you're free to respond to offers for items offered by other members.
You might want to consult this online resource from Kodak regarding your camera for further information about it.
Please take a moment to rate my answer.
Mar 13, 2010 | Kodak Advantix C650 Zoom APS Point and...
How do I open the compartments on the camera
Which compartments?
The lid on the battery compartment next to the tripod mount flips down.
To open the film compartment, turn the camera upside down, then turn the film chamber release clockwise.
You can download a manual from
Feb 08, 2010 | Minolta Vectis 300L APS Point and Shoot...
How to open filnm compartment of old 35mm nikon
Is it an SLR model?
I am not familiar with Nikons; however, Minolta and Canon SLR film camera's film compartments are opened by lifting up on the film rewind mechanism on the top left side of the camera.
If the Nikons are designed like Minolta and Canon, there will be a small tab to push in at the bottom of the camera. This releases the film and allows it to be rewound. At the top left will be a small rewind lever that is used to do the rewind. The part of the camera that the rewind lever is attached to is pulled up to open the back of the camera.
Oct 14, 2009 | Instant Cameras
Stuck remaining exposure count despite new film, new film unlded
You might try closing the film compartment without film in it and press the manual rewind button. This might reset the counter circuit.
Dec 08, 2008 | Kodak Advantix 2100 Auto APS Point and...
Disney princess camera
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Instant Cameras
Open Questions:
Instant Cameras Logo
63 people viewed this question
Top Instant Cameras Experts
Steven Wander
Steven Wander
Are you an Instant Camera Expert? Answer questions, earn points and help others
