Question about RaidMax NINJA 918 ATX Case
Fan not lightning up
Hi. My fan in the back of my case are not lightning up with the blue light. Iam pretty sure that it should do that. The fan works but no light is comming out. What can I do to fix this?
Lasse Denmark
  • 93 Answers
Re: fan not lightning up
There should be 3/4 small led (light emitting diodes) on the inner of the fan check the integrity of the solder on the wire to this led strip if there are any breaks in this then it can be re soldered.
if the fan is part of the PSU (power supply uinit then consult your local pc repair shop do not open the PSU.
If its just a case fan it would prob be easyer just to replace the fan.
hope this helps
Posted on Nov 04, 2007
0 characters
3 Points
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Looking for a manual for a Chenbro 84H220910-074 drive cage. I bouoght 3, and there was no manual with any of them. Nothing on thier site, and no response from thier tech support.
this is from a newegg feedback. the manual is not on their site but according to this guy comments here it is to configure
Pros: It works.
Find documentation here:
There are extensive connections for fans, alarms and RAID cards (activity & error lights) . Configurable 'high temp' and fan alarms.
Cons: Documentation VERY hard to find.
For the drive trays, Blue power indicator, and green activity light are passed from back-plane to front of drive tray with 'light pipes'. The blue is too bright and bleeds into the green, making it difficult to see the activity lights.
Also, both power connectors need juice or the alarm on the tray goes off. Since I am not using redundant power supplies, I eventually used a 'Y' chord to apply power to both inputs. Not a big deal, just took a while to figure out why the alarm wouldn't ******* (this before I found the documentation mentioned above).
Other Thoughts: The cooling fan is LOUD. I'll look for a more quiet one in the future.
Mar 28, 2011 | Chenbro 84H220910-074 Hotswap HDD Cage w/...
Computer is not booting up. Usual blue light over power switch is red.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
Feb 15, 2011 | Thermaltake Wing RS 101 Case + 430W PSU:...
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Raidmax fan+light
Fans are such a low cost item I would replace the fan or fans and take the troubleshooting from there.
Fans can be prurchased from or best buy ETC..
Dec 07, 2007 | RaidMax NINJA 918 ATX Case
LCD display on case not working.
Did you try to reset the LCD?
Hit + - at the same time.
If that dont work contact manufacturer for replacement.
Nov 09, 2007 | XG Viper 2 ATX Mid-tower Gaming Case...
RaidMax NINJA 918 ATX Case Logo
117 people viewed this question
Top RaidMax Computer Cases Experts
Brian Sullivan
Brian Sullivan
soumen dutta
soumen dutta
Are you a RaidMax Computer Case Expert? Answer questions, earn points and help others
