Question about Frigidaire Refrigerator Light Switch - 5303289051
Ref. Whirlpool model ED25DQ/ water in meat drawer
24 hours ago I turned the refergerator temp down because the
food on the door wasn't cold.It is set on a 3.
We have a meat storage drawer at bottom that I only put fruit in
it has a seperate control I set on COLD. Now I have a puddle of water
in the Meat/Fruit drawer. What do you suggest?
    Brigadier General:
  • 4,090 Answers
You seem to have conflicting information here.
If you turn the therostat DOWN it is setting it to defrost that will not help the food in the door to get cold it gets it warmer. The water is possibly from the fridge being in defrost mode and the tube that usually direcfts it to a tray beneath the fridge to waste tray that evaporates the water from the heater coil has somehow been directed back into the crisper draw.
tfry turning the fridge to colder not warmer. Hope i interpreted this correctly, language is a wonderful tool when facial expression and visuals are available otherwise its a handicap
Posted on Jun 22, 2009
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
I have a whirlpool refrigerator and the veg/meat drawer that I keep the potatoes in keeps getting so cold it freezes anything in that drawer. I have changed the controls and can't seem to stop it. ...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 14, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My produce keeps freezing in the crisper drawer-the temp in the fridge is set on medium (5) and the humidity level is on the middle setting in the crisper drawer.The drawer is not jam packed with...
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Sep 09, 2011 | GE Profile PDS22SBRR Stainless Steel...
My Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator bottom meat section and veggie drawer is freezing my meats and vegetables. Why?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
NOT MAKING ICE JUST HOOKED UP WATER LINE AND TURNED ON TWO HOURS AGO
if you have just purchased the ref. and hooked it up it will take 24 hours for the ref. to get to correct temp.Plus the ice maker wont start to work until the freezer temp gets to 15 degrees.if the ref. has been in use then check the power button on the ice maker itself and make sure the power is on.
Nov 03, 2010 | LG LFC22740 Bottom Freezer French Door...
Ice/water is forming in the non freezer sections,,,dripping into the meat, veg, etc. drawers. Is it just a cheap machine and there is nothing I can do about it?
Turn it off for 24 hours, pull all food out of course. When you turn it back on keep your cold control no higher then 3. Sounds like your drain froze. If problem
Appliance Repair
Oct 22, 2009 | Refrigerators
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Water pooling inside fridge
check if there is a drain hole in middle of gulley at back of fridge. this is probably blocked. push something flexible down hole and check water drains freely by pouring a small jug of water in gully
Jun 05, 2007 | Kenmore 51262 / 51264 / 51269 Side by Side...
Maytag fridge s-by-s freezes alot of the stuff at the back and lower vege drawer
Actually this seems about right. The air flow in the fridge is usually from the back top of the fridge. That will be the cold spot then the air sinks down to the bottom and then recycles back into the freezer comp. to get cold again. Door shelf is usually warmer than the rest. As with most units, it takes some understanding of the air circulation pattern in order to find the sweet spots for dairy products and meat, veggies, etc. Check to see if there are slider adjustments on the drawers for temp or humidity, etc. Also make sure there are not parts missing from the inside of the fridge. Sometime a part that appears to only be a small plastic item gets broken over time and never replaced when it could actually be very important to air circulation. I recommend getting a small floating aquarium thermometer and setting it in a glass of water in order to get the "true" temp. of the products not just the air temp of the fridge. Put the glass in different locations over a weeks period to record what the temps are like in different areas of the fridge so you can make a "map" of the cold spots, etc. Leave the thermometer in for about 12 hours before you record the temps for that location. I think you will find the answers you need in order to place your food more effieciently in the fridge. As for summer days, the unit will have to work harder in warm weather to cool than it does in the winter months of course but there is always a concern that you are not cooling 100%. The way to check that is to let the unit run for several hours (turn the temps down so it runs for at least an hour solid) then you would have to pull the whole interior rear freezer panel off the back to view the cooling coils and make sure they are fully frosted across the whole coil surface. If they are iced up only in a few inches of coils then you likely have leaked out the liquid refrigerant over the years and there's not enough to cool a full 100% of its capacity. And your complaints are the same with even brand new models... it's about 60% of our service calls (not cooling properly or freezing food).
Jan 28, 2007 | Maytag MSD2756GES Side by Side...
Frigidaire Refrigerator Light Switch - 5303289051 Logo
262 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
