Question about Kodak EASYSHARE 300 Photo Printer
I want easyshare photo printer COLOR CARTRIDGES.where do i get em
I have plenty photo paper left over from running out of ink in my cartridges. Do I throw 125 Photo papers away.
  • 484 Answers
No. Simply use the paper when you get new color cartrides.
Posted on Jun 21, 2009
My HP Inkjet 6122 has suddenly started printing color photos with stripes. I don't use it very often, only when I need color photos. I have replaced both the #45 black and #78 color cartridges with genuine...
Use the HP Printer Assistant software tools to run a "head-cleaning" cycle -- the problem is not with the ink (there is plenty of it) but with the print-heads (that **** the ink, and then spray it onto the paper). Some of the jets are clogged, and so you get "white-stripes".
Aug 19, 2010 | HP DeskJet 6122 InkJet Printer
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Why are only black and yellow printing?
The printer has two ink-cartridges: black and tri-color.
The black cartridge has ink left.
The tri-color cartridge has run out of 2 of the 3 colours of ink.
Buy a replacement tri-color cartridge,
and responsibly recycle the "empty" cartridge.
Nov 19, 2009 | Canon i9100 InkJet Photo Printer
Im getting a line through the photograph when the photo
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak EasyShare Printer Dock Series 3
Giant blobs of ink on every photo...
If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Color ink want print after installing new cartridge
Take out the cartridge first get a couple paper towels fold them put about a teaspoonful of water in the center to get a wet spot then place the cartridge on the paper towels. the ink will soak out, use it to get the cartridge working may take a few tries, but it works. the place in printer and run a cleaning. secret is never let them dry-out and refill before it runs out.
Mar 26, 2009 | Lexmark Inkjet Z517 Photo Printer
My printer will not print black ink.
I had the same problem & I think it was I had the wrong color on the Copy screen.
Dec 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Help Please!!!!
goto windows paint program and draw and stick man..
in pure Cyan and print
in Magenta and print
in yellow and print
This will tell you which ink within the cartridge has run out.
If you find that only blue is left then well you need a new cartridge or refill the old one with the above inks
Jul 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 300 Photo Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
