Question about Cycling
Cannot get it out,do i need a special tool? - Cycling
  • runt runt May 11, 2010
    need more info on what your trying to remove
  • Michial Gueffroy May 11, 2010
    What are you trying to remove?
  • 3 Answers
Depends whether you can't get it off because you are stupid, weak or using the wrong tool doesn't it...
Posted on Nov 13, 2009
    President:
  • 1,138 Answers
Try going to www.parktool.com. Surf the site and under tools you will see pictures of the various tools and their application. If it is something on your bicycle that a screwdriver, hex wrench, pliers or socket set won't remove it is probably a special tool. Also some fasteners on bicycles loosen in the opposite direction from what you may consider normal(left hand thread). Sometimes your public library will have a bicycle repair manual that you can look at or copy pictures from. Also try http://sheldonbrown.com/harris/tools.html He has an excellent website.
Posted on Jun 25, 2009
Replacement right rear passenger hand operated window have broken window can't get window handle off
U need a special tool to remove handle. There is a clip and this needs a tool that will push the clip off and allowing u to remove handle.
May 10, 2018 | Cars & Trucks
What are the torqe specs for 2006 H3 fan/clutch and water pump
special tools you need EN 48543 FAN CLUTCH HOLDING TOOL. J41240 FAN CLUTCH REMOVER AND INSTALLER. TORQUE FOR FAN CLUTCH NUT 41 LB FT. FOUR BOLTS TO FAN BLADE TORQUE 20 LB FT.WATER PUMP BOLTS TORQUE TO 11 LB FT. DONT NEED SPECIAL TOOLS REMOVE WATER PUMP.
Nov 29, 2012 | 2006 Hummer H3
How to replace a Jaguar X Type fron wheel bearing
Jaguar 2000-06
Wheel Bearings
Removal & Installation
  1. Remove the brake disc.
  2. Remove and discard the retaining clip. Detach the ABS sensor.
  3. Remove and discard the O-ring seal.
  4. Remove the wheel hub and bearing retaining bolts.
  5. Remove the wheel hub and bearing.
  6. Prior to applying sealer, clean the ABS sensor sealing surface and the ABS sensor aperture sealing surface.
  7. Install a new O-ring seal.
  8. Apply a 2.5mm bead of Loctite Ultra Blue 587 Silicone (RTV) sealer to the ABS sensor sealing surface.
  9. Install a new ABS sensor retaining clip.
  10. Install the hub/bearing assembly. Tighten to 90 Nm.
  1. Remove wheel knuckle.
NOTE When removing the wheel hub from the wheel knuckle the bearing will be destroyed and the bearing inner ring will remain on the wheel hub.
Fig. Using special tools, remove the wheel hub-X-Type
  1. Using special tools, remove the wheel hub.
  2. Using a suitable tool, remove the bearing inner ring.
  3. Using special tools, remove the wheel bearing.
    Fig. Using a suitable tool, remove the bearing inner ring-X-Type
    Fig. Using special tools, remove the wheel bearing-X-Type
To install:
Fig. Insert special tool 204-312 in to 204-309-X-Type
  1. Insert special tool 204-312 in to 204-309.
  2. Support the wheel knuckle on special tools.
NOTE Make sure wheel bearing is correctly orientated with the colored side facing inboard.
  1. Align the bearing over special tool.
  2. Using special tools, press bearing into wheel knuckle.
  3. Change special tool 204-312 to 204-313.
  4. Align the bearing and wheel knuckle over special tool.
  5. Slide wheel hub over the guide and align to the bearing.
  6. Using special tools install the wheel hub.
  7. Install the wheel knuckle.
    Fig. Using special tools, press bearing into wheel knuckle-X-Type
    Fig. Change special tool 204-312 to 204-313-X-Type
    Fig. Align the bearing and wheel knuckle over special tool-X-Type
    Fig. Slide wheel hub over the guide and align to the bearing-X-Type
  1. Raise front of vehicle and support on stands.
  2. Remove appropriate road wheel.
  3. Using wire or string, secure brake caliper to road spring to take weight off brake hose.
  4. Raise vehicle sufficient to provide access for special tool 204-111.
  5. Install special tool 204-111 in road spring.
  6. Slacken tool adjuster to suit spring length.
  7. Install adaptor and thrust collar.
  8. Position stem of tool in center of spring passing dowel through slot in suspension turret.
    Fig. Install special tool 204-111 in road spring-XJ Range and XK Range
    Fig. Position stem of tool in center of spring passing dowel through slot in suspension turret-XJ Range and XK Range
NOTE When turning tool adjuster, ensure that tool stem does not rotate and disturb position of dowel in suspension turret.
  1. Engage dowel of special tool 204-111 in suspension turret and rotate to position across slot.
  2. Lower vehicle onto stands.
  3. Rotate tool adjuster to tension spring.
  4. Remove wheel speed sensor securing screw and withdraw sensor from vertical link.
  5. Remove nut securing tie rod outer ball joint to steering arm.
  6. Release ball joint from vertical link.
  7. Install special tool 211-098 on tie rod outer ball joint.
  8. Tighten tool bolt to release taper pin from vertical link.
  9. Remove special tool from ball joint and position tie rod for access.
  10. Remove nut securing upper control arm ball joint to vertical link.
    Fig. Install special tool 211-098 on tie rod outer ball joint-XJ Range and XK Range
continue...
Aug 03, 2010 | 2002 Jaguar X-Type
91 chev corsica location of starter, any special tools needed
Nothing special about the tools but you will need to make sure you add the shim correctly
Feb 02, 2010 | 1991 Chevrolet Corsica
Compress FRONT Caliper on 2008 Town Country
You can compress the piston with a simple C-clamp. other than youre basic tools you will be okay nothing special required.
Dec 17, 2009 | 2008 Chrysler Town & Country
Need to replace gas filter but looks like i need a
This special tool is available at your local auto parts store. Ask your parts expert what size you will need. The tool is fitted around the fuel line and pushed into the fitting on the filter. Make sure you relieve the fuel system pressure before proceeding.
Oct 29, 2009 | 2001 Chevrolet Silverado 1500
Is there any special tools to change the brakes on a 2000 lincoln ls
standard hand tools, remember to have the rotors turned by a machine shop.
May 26, 2009 | 2000 Lincoln LS
Need to replace a clutch in a 1994 honda civic whats the best way to do it and what special tools and parts do i need
no special tools as long as you buy a quality clutch kit that has a disc line up tool. these cars are come of the easiest i have done. you will need a 32mm socket for the CV axles (not a special tool, but fairly large for your average tool kit to have) a floor jack with a block of wood is needed to support the engine. other than that, very straight forward.
May 03, 2009 | 1994 Honda Civic
I NEED A SPECIAL TOOL BUT DON'T KNOW WHAT IS IS CALLED
you will need 2 special tools, one is the crankshaft locking tool the other is the camshaft gag or alignment tool
Mar 24, 2009 | 2001 Volkswagen Passat
Cycling Logo
63 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
